  • Replies 79
Is that what you said when you got on the pocket bike? :cool:
All the flesh and skin has grown back now! :(
And if you must bash your head on a brick wall try placing a feminine hygene pad on your forehead first!!
(c%#! head)!!! :laughing-smiley-014:
there are ways around it!
i know of some people who have taken thier (r33 gts-t) power/weight fine to court, contested it and won!
and now that they have won once.... they can never be fined for it in their same car again!
Ruffels,
on what grounds did they contest the fine?
I'm so desperate for a solution I REALLY don't wanna sell my car :P
....and I know of some people who make up stories to try and look cool.
feck! just lost 3 points. my fault, had it coming. somebody clear this up for me. my mate rekons that p plates last only until you turn 21 and then you get your full licence. i was under the impression that it takes 3 years from time of issue till you can move on to your full.
http://www.vicroads.vic.gov.au/Home/Licensing/GettingYourPs/
QUOTE: If you pass your test, you will be issued with a Probationary drivers licence which is valid for three years. During this time you will have certain restrictions imposed on you.
wait for it,
the answer to this p plater problem is not in the weight, but in the power. i cannot be bothered heading to vicroads site to find quotes or such to back this up, but those who live in fear of these laws will know exactly what it is that i speak of.
in order to be able to drive a hpv on your p plates with out heading through loop holes such as the only car method, you simply have to lower the power to stock weight ratio through modification, this needs to be tested and vicroads needs to be informed of this. i do not know if simple down tuning can resolve this, you may need to question that further with vic police and such, but this does work with the removal of forced induction, i have also heard that this works with certain fuel efficiency mods although i do not know what they are and that is unconfirmed.
hopefully that helps.
now watch as some righteous fool absolutely flames me
Go with the unconfirmed there dude... because you wont be able to confirm it in this life time as (like most of the other posts) wrong.
Removing the turbo doesnt constitute having a non-turbo car.
Fact of the matter is its still a R33 GTS-t by the build plate, and EPA to boot.
You'd need to change the motor to a RB25DE, so basically, waste of time.
Simply taking off the turbo is not acceptable.
Great way to kick off your first post, more heresay
$1100 is $1100. There is no scaled increase.
Its $1100.
Straight from a TMU officer when specifically asked about the new $1100(max) fine:
Maximum penalties are set by the government, and relate to court imposed penalties. The prescribed penalty for an Infringement Notice will be considerably less than the maximum penalty that can be imposed by a court.
Also,
The R33 GTS-t is already a banned car.
Yeah, the R33 is currently banned, but only because it makes too much power for its weight. The actual car is not blacklisted, or anything of the sorts (for pre july 1 p platers). Because they specify the power from modified cars has to be calculated (and that's in plain print), it is not so unreasonable to assume the same for "mods" that decrease the power. If I am wrong in this assumption, please prove me so.
For a mod, you seem to be throwing around a lot of false information as fact. You are not setting a good example. In future, please back up your statements with links/quotes so that we may have a constructive discussion on this issue.
my head hurts from all the rumours everyone is constantly posting ~_~
Check if your car is high powered
If you are a probationary licence holder, it is your responsibility to make sure that any vehicle you drive is not a high powered motor vehicle.
You can:
* check with the manufacturer for engine power and vehicle weight information; and
* calculate the capacity to weight ratio
Stock power to weight. End of story. Not your current power/weight from adding power reduction mods or adding more weights. Stock power to weight.
zogm http://www.arrivealive.vic.gov.au/c_youngGLS_9b.html
You conveniently overlooked the following line from both that website and this thread.
If your car is modified, you may also need to obtain an engineer's certificate and do your own calculations.
Now you've done it ;)
f you obtained your P plates on or before 30 June 2007, a high powered vehicle is considered to be any vehicle with a power to weight ratio over 125 kw per tonne, or with an engine capacity to weight ratio over 3.5 litres per tonne. This includes any make of car.
Source
The R33 GTS-t is over the power to weight. It does not need to be "black listed".
From the factory the car is over the limit. As above, it doesnt not need to be on a black list. Is that not clear enough after 3 pages or what?
From 1 July 2007 the penalty for driving a high powered vehicle will be three demerit points and a maximum fine of approximately $1100. These penalties will apply to both the current power to weight restrictions and the new high powered vehicles restrictions.
Source
Meh, near enough. The max is $1100. So you dont get that the first time. Wow.
If you get pinned twice/3 times etc etc. You'll soon find out that you'll be punished with the $1100 regardless of how stupid you try and look in court :laugh:
I know having been to court for an offence the second time, the Judge doesnt look too highly on you.
Because the second time in 12 months you get pinned you loose your license anyhow.
This due to the 5 points in 12 month scheme. Do i need to explain that one to you?
So... in moving along
VSI #8, Section 10
Also adding weight to a car doesnt not just "give" you approved extra weight. Or get you around the laws because you made your own calculations.
Clearly states you must attain engineers approval in the VSI, and also here
If your car is modified, you may also need to obtain an engineer's certificate and do your own calculations. You are also required to notify VicRoads of any significant modification
Source
And also dont forget
The weight of a vehicle is the unladen mass specified by the manufacturer for the stock standard vehicle (without options).
Source
More info to come tomorrow after i chat to a few people on a few other things
And also use the search button as i've gone into some of this in times past
Here we agree. But have a look at that statement again. "any vehicle with a power to weight ratio over 125 kw per tonne", and it ends there. It does not go on to mention which cars are over this limit.
This point, combined with the point regarding modifications, is the basis of my argument that it may be possible to bring a car below the power to weight limit. If a r33 gtst is modified in any legal way to have, for arguments sake, 160kw, then it is no longer over the power to weight ratio. Can you see where I'm coming from?
There's no need for snide remarks.
Nice save.
No argument there. If you'll recall that's why I mentioned engineer's certificates in my first post.
Fair enough. So the weight is set in concrete, but as lexi bro! suggested the variable "power" is still in the game.
R31Nismoid (and others), don't get me wrong, I'm not arguing just for the sake of it. But I certainly don't appreciate being shut down every time I bring up a not so implausible suggestion to this very real problem. Just because it doesn't concern you does not mean it's not a heartache for other drivers.
God there is so much crap surrounding this issue, I am in the same boat as all the P platers who have this problem, I am simply giving my car to my mum, she barely drives, and I get a nissan in return, I'm not complaining, whether it be a pos pulsar or not, I seriously suggest we either sell up (sucks so much yes I know) or just organize another vehicle for the time being, regardless of all these silly rumors of people winning against the government, it's just not bloody worth the bother.
People who try argue with R31 Nismoid usually lose from what I can see.. so I wouldn't bother + he's wanking in his avatar, that proves he knows his stuff.
It does not need to mention cars which are over the limit.
What part of that dont you understand?
The past 3 pages i think everyone has told you in every different way possible and you still dont understand that the R33 GTS-t is over the power to weight laws, and there does not need to be some mystical listing of all banned models for a car to be deemed ILLEGAL
As for the rest, you try and prove to an engineer you have lowered the power by a means that cant be altered, because any change you do make requires the good ole EPA test. And then your talking 1/3 the value of an R33 GTS-t just to pass, so again, its not a viable option on a car thats worth 15k when it costs you another 5k just to get it "possibly" legal.
That's what I was saying! you're the one saying the r33 is already illegal for a p plater so can't be made legal.
if the r33 gtst was made to have less power it would be NO LONGER OVER THE POWER TO WEIGHT LAWS.
you REALLY need to work on your comprehension skills.
as for the costs involved, they are irrelevant at the moment. we're discussing all the ways a p plater can legally drive a r33
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
