bought a 180 with the front smashed in witch we will be converting to a sil80 and dropping an RB into.
some people believe that they can be a bit front heavy for drift but gonna give it a crack anyways.
it will have FMIC, pod and probably bigger fuel pump. and will be running higher boost on stock turbo (about 12 - 14 pound)
will be getting coil overs and strut braces as well.
how do you recon it will handle and what sort of power do u recon i would get???
https://www.sau.com.au/forums/topic/166764-rb20-turbo-sil80-drift-car/
My drift car is a Onevia with a Rb20 in it and a RB25 box.
Completely stripped interior just a RB25 highflow, remap, 3" exhaust, front mount, Tein coil overs, welded diff and a 5 puk button clutch. :)
No problems drifting whatsoever.
Do it and have fun :P
The Cefiro cross member is the best to use as it will sit the engine a couple of cm lower then when using a R32 GTST cross member.
Just get your suspension sorted out and it will be easy to throw around.
A 1 piece tail shaft is fine and most big truck shops like Gibbs can make you one up relatively cheaply.
If you have any questions feel free to send us a PM.
I think what people are trying to tell you is how much effort and cash is needed to make it a reality . A long heavy motor thats no torque mountain in std form - for drift . No competitive engine is going to be cheap regardless of if its in the car or on the floor . I think you'll find in this day and age more factory and aftermarket goodies for SR20's than RB20's which means greater availibility and lower cost for the right bits . I can partly understand why in the US there is this S13/RB20 craze - no R32/33/34's or SR20DET USDM cars . If they'd had the R32GTST they wouldn't bother converting S13's . When you can have 400 ft/lbs of torque from a half serious SR20 at 4500 rpm why would you plonk an RB20 into it ?
One more time , said this last time .
Search FreshAlloy.com Forums - Twin scroll question .
Cheers .
Putting a RB20 makes zero sense.
...except they are cheaper, stronger and possibly make the same/more power. Im yet to be convinced that a std SR20 can make the power and response a sorted RB20 can. I think its more to do with the fact that there are so many ppl spending money on SR20s its easy to find a good one. The same cant be said for RB20.
They arent the best engine. But if dollars are tight then i think the RB20 should be on the radar.
id say that is more a tuner fault, SR's are far more det prone than rb20s for sure and 90% of sr's failures are ring land and the rest are big end...... due to det. i have only ever lost one SR and it was a dodgy HKS injector that stopped working.... killed number 3.
sure they are cheaper but by the time its installed 2500 goes quite a way to making pwr on the sr. if it is NA to start with then yes probaly makes sense.
i see SR packages from 1500 regulary you just need to look.
as slide said im using r32 gtst cross member and i needed to lift the bonnet a bit to fit the engine under it
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
