  • Replies 100
Hahah yeah i think dose is a pretty funny word lol but how it is related to flutter i do not know....
Why not make a 'dose pipe'?
I think that turbo cars that dont make any noise are just plain boring. >_<
*awaits flamage*
I think "dose pipe" is as funny as hell but it's an open forum and I'm sick of seeing new users hammered for asking questions or having different views to the majority :)
I dare you to join the minority group and see what happens to YOU :sorcerer:
Dose pipes, metal intake pipes, flutter.. it all means the same thing --- SSoooOTuTuTuTuTU!!
Who cares that you get defected for it, if you drive a skyline and a cop makes you pop your bonnet you get done for any stupid thing they feel like pickin on anyway...Mehhh!
PS-don't need to get off the topic and add other bs, relate your post to my original topic thats on page ONE!
.......................................Suuuukutukutukutututu....................
Translated as:
Suck you too, k, you too, k, you too, you too, you too............................... :/
I have one of those apexi metal intake pipes, I can confirm that the intake noise is louder than a plastic one. It is also more high pitched.
I tried blocking the BOV off, and yes full hektic flutter was abundant. But I wa not a fan of the overfueling, stalling and whatnot.
if it's being detrimental to my car, then the care factor is f*cking huge.
Couldn't think of anything worse that to intentially create mechanical problems to my car
What mechanical problems does a metal intake pipe create for your car?
he is talking about leaving the bov blocked off and lettting it surge its ass off every time the throttle body closes
it's arguable that letting the compressor surge its ass off every time causes damage, i agree
do a survey of 100 vl turbos with captain insano surge and ask them how many have done turbo rebuilds
care factor. soo! soo! soOOkutukutukutututu...
:ermm:
So are you going to post anything of interest or a bunch of letters each time?
Pointless threads get sent to the wasteland, and this isnt far from it now
I run a 6 inch straight metal pipe off the turbo with a small filter on the end, I beleive it should "by theory" suck in more cool air than my last setup which was a pod filter fitted up near where the standard airbox was mounted. The piping to the pod was mostly steel apart from 1 90degree bend which was rubber. Im still yet to test to see if the straight pipe is more responsive because my clutch is slipping so I don't want to drive it on boost till I get a new one.
And yes it makes it sound exactly like a vl turbo, its "doses" are insanely loud, too loud sometimes when you just want to drive normally.
Oh and I run after market computer so no afm and blocked bov - hence the very loud flutters.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
