hey guys
changed my gearbox oil this wkend - seems to have made a nice difference especially gear changes higher up the rev range (ie: when booting it). Heres the link on my site below...
anthonymcgrath.co.uk - changing your gearbox oil
https://www.sau.com.au/forums/topic/169551-changing-gearbox-oil/
thanks motoman I'll amend my tut to include that :O
have to say at first I did think my filler plug weren't budging but it was just the glue/sealant around the thread. I was more worried at the very very loose gearbox drain plug!!
although only going to work if there is two of you. i refill my oil by using a 1.5m piece of flexible pipe with a funnel attached to one end. (i think its about 12mm in diameter.. although could be bigger...)
Run the funnel though the drivers side of the engine bay. Have one person ensure that the pipe stays pointed into the gear box filler hole while the other poors the new oil into the funnel. much easier than getting up and down lotsa times.
Cam
If you have 3 different sized ratchets in a set, you'll find the biggest one fits in perferctly without any attatchments.
Also, i bought some of the red coloured sealant/thread locker to stop the screw coming loose later.
Can't remember what it was called.
i believe its called lock tight ?
I think you will find that it's a 1/2 " drive ratchet that will undo the bolts. also, on r33 you can remove the gearstick suround and rubber boot and just pour it in from inside the vechile
You sure pooring it in from the gearstick surround is ok???? sounds much easier.
My gear stick surround is all torn and broken is it posible for the oil to dry up??? changing gears seems very stiff just lately and did a box oil change only 10k ago!
hopefully i'll be doing this on the weekend and i'm gonna give the filling through the gearstick option a go (i'm sooo scared of pouring oil all through my car though cos I'm so impatient when pouring oil through a funnel!)
If that for some reason doesn't work (no reason why it shouldn't off course) i'll just use a $3 syphon hand pump i reckon.
  • 1 month later...
Thanks for the writeup!
However... I tried this today and failed :D First, I dented the chassis rail with a stand. I thought the chassis rail was supposed to be tough enough to put a stand under. Where is a good place to put stands?
Then, I couldn't get the filler plug out. I had about 40cm of leverage but it just wouldn't budge.
Just to be sure... it's anticlockwise to undo, like everything else, right?
Would it be OK to use a hammer on my lever to get it started?
Hi there, have a read of this for jacking locations:
Also, you could try using a hammer, but I recommend getting something to extend your breaker bar/ratchet... nice length of pipe to get some more purchase, and soaking it in some WD40 will help. The filler plug is tapered so thats why it's so tight...
And just remember lefty loosey, righty tighty :laugh:
  • 11 months later...
I might try this fairly soon. I was also told, if you are tight-arsed about doing it properly, you pour a litre and abit of kerosene into the gearbox once the oil
has drained. Start the engine and push the gearstick into gear (without the clutch) so its resting on the gear but not actually going into gear. Apparently this
engages the synchros and cleans them. Once done drain the kerosene, fill it up with oil + some nulon G70 stuff and should be good :thumbsup:
Ill be doing it soonish so ill post it up on how it goes :P
make sure u got room infront of ur car incase u do put it in gear and it hops into wall, other car, human etc. never heard of this mate but good luck with it
Edited by skylinekid
My dad says thats how he did it on the old R31 we had. It just involves pulling apart the centre console, removing the boot and pouring it in from there. Not to way to do it if you have a habbit of getting oil everywhere... like me :bunny:
I'm going to change my gearbox oil this weekend (I think) so I'll take pics if I decide to do it from inside the car :happy:
  • 6 months later...
this is probably kinda stupid to ask, does the gearbox reservoir goes to lsd reservoir as well?are they linked?or they're both independent?
The LSD is a limited slip differential. The diff or diffs (in a GTR) have there own drain and fill up point, as the oil needs to be around the diff's crown and pinion wheels for lubrication.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
