Sandown Sprints This Sunday - June 10th - Driver Training Only $90!
  • Replies 127
Posted Images
check the event calendar pat - all the track days are listed on there
AUGUST - 12 Sun - SAU Vic Track Club Championship - Round 6 - Sandown
woot! i presume this will have driver training too?
http://www.cams.com.au/content.asp?PageID=Clubs and look at all the different club sites to see what is on when.
Usually if I want to go somewhere I check the following club calanders other than ours/wrx:
AROCV
Maserati
FPV XR / HSV Clubs (run events together - am doing Winton with them this Saturday)
HSCC
PIARC (what we did on the weekend. Next one is Oct 20/21)
MSCA
But Scotsman and I did keep the weekend a little on the low down as we just wanted a quiet settle in run before our public return. :thumbsup:
You realise Aaron that this will be the 1st time we have actually been on the track together with working cars? Other than your original trip to PI when the car was basically stock.
So it's the first real 05 v 06 SAU Club Champion showdown. :thumbsup:
So it's the first real 05 v 06 SAU Club Champion showdown. :rofl:
No shit, really? :thumbsup:
In that case... GO AARON! :P
How do other club members get to find out about these track days? I had no idea the Island was on last weekend.
Aaron,
We put this calendar together early in the year....
track2007___completed.zip
... and when we say stripped, we mean he's REALLY stripped it. lol wait n see. That thing is an animal... 1:16 is quick.
Snowy, good to see your car back in action - go get 'em tiger :thumbsup:
Kennedy has stripped his car and is running slicks so we are no longer "competing" against him as such. It is no longer a street car.
They aren't slicks - just have less grooves than RE55's, Hoosier stylz :D
He thinks that they aren't as sticky as RE55's anyway.
Sandown will be good. A pity the stig won't be there.
They have a UTQG of 0. lol.
Mark Webber drives around with grooves in his tyres but you don't call them street tyres. They are slicks.
It depends on what exact model of Hoosier he is using because the A3S05/R3S05 Hoosiers have a UTQG of 40 and they look mighty similar to his and the one in your pic for that matter.
http://autospeed.drive.com.au/cms/A_2912/article.html
Also, if they were considered to be as sticky as a slick wouldn't CAMS require the cars fitted with these to have cages fitted?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
