  • Replies 233
doodz
SV7795978
That's your Express Post package number.
Call your local Post Office and give them a razzing.
According to 13-13-18 Press 3 then press 4. The person said that it was "delivered" on the 21st Aug 2007.
However I have not recieved it, nor have I gotten any slips re "Notice of pickup" from the local post office.
I asked them for the direct number for the local post office they said "because it is private we cannot give that out"
I wil have to take time off work ~1hr and physically goto the post office to check and "maybe' it will be there.. Which in turn I'll lose money because Im not working....
GRRR
Bass this isnt directed at you. It's for my local post office, they are a bunch of wankers and I want to send them anthranx and bomb them.
Edit: I was able to locate the direct number from other forums and rang them and they do infact have the express post at the post office.
Thanks!
Installed my silicon intake pipe last night took me 3 hours from start to finish,
Fits nicely after a bit of trimming to the two little holes.
I've got it fitted with a Mr_Crust airbox and the silicon was flexible enough to refit it in the mr_crust airbox so i'm happy :) i'm sure others that have pod filters who need the intake pipe to bend enough for the pod bracket to be bolted back on shouldn't have any issues either.
Anyone have final pics of the product ontheir cars?
Installed on weekend. Still using standard airbox. Mind also needed trimming on all inlet/outlets.
  • 2 months later...
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
