hey guys was just looking for some info on installing a front facing plenum and i found this beauty, not sure if its been posted b4 but it looks the goods.
http://www.nissanpacific.com/reference/rb/index.htm
This is what the site contains
Day 1
Cross Pipe Removal
Day 2
Thermostat Housing Removal
Intake Removal
A/C Bracket Removal
Day 3
Crank Angle Sensor Removal
Timing Chain Cover Removal
Day 4
Timing Belt Removal
Water Pump Removal
Thermostat Removal
New N1 Water Pump
Oil Pump Removal
Day 5
Water Pump Install
Oil Pump Install
Timing Belt Install
Day 6
Intake Manifold Install
Day 7
Oil Pickup Install
Oil Pan Install
Oil Cooler Bracket
Timing Belt Cover Install
Day 8
Motor Mounts
Nismo Thermostat Install
ATI Damper Install
Alternator Install
Day 9
Spark Plugs
Flywheel Install
Clutch Install
Transmission Install
Mount the motor
Day 10
Heat Shield Removal
Turbo Manifold Removal
Stock Ex. Manifold Removal
HKS Wastegate/Manifold
Day 11
Broken Stud
Day 12
HKS Wastegate
HKS Manifold Test Fit
Day 13
Q45 Throttle Body
Silicone Connector Tips/Tricks
Intercooler Cold Pipe
Day 14
Turbo Clock
https://www.sau.com.au/forums/topic/171375-found-an-awsome-site/
240z ? but anyhow, some useful general info in there.. Looks like you have to swap the sump for a 240
To go into an R32.. you don't need custom mounts, you can just use the existing RB20det ones. Unbolt them, and bolt them to the rb25..
Thats where it went!!!
That used to be another site and was extremely useful, i had it on my favourites list, a few months ago however it disappeared and the link was broken. He must have take it to another site!
Thanks for linking it, very useful info.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
