  • Replies 46
too right it would be, :-) i take some if you do make them. searched for ages for something like it. would not ba as simple as those i think... well on a R32 anyway and being able to split them rather then removing the drive shaft
Edited by tacker
https://www.sau.com.au/forums/topic/172697-brake-duct/#findComment-3177733
it seems like it only cools the very centre of the disc... wouldn't it be better to have a duct cool the outer edge of the disc where the pads make contact or even ducting cool air into the the cooling vanes in the centre of the rotor? I reckon make somthing like a caliper that goes over both sides and the top of the rotor then duct cool air from the front bar into that... just my thoughts.
https://www.sau.com.au/forums/topic/172697-brake-duct/#findComment-3181781
they do spray water onto the brakes of a DTM car but only when they are coming into pitlane as stopping with red hot brakes causes fade when they return to the track or so the article i found said. Also those truck they race pump water onto the brakes all the time.
I have also found some 3" 12 volt fans that are used in nascar to cool brakes down. They are place in the brake ducting and will move 145CFM i think that would help.
Edited by tacker
https://www.sau.com.au/forums/topic/172697-brake-duct/#findComment-3183429
used to run water cooling in f1 as well as a way to beat minimum weights....they'd get weighed with 30kg of water on board then dump it on the brakes nice and early, then run around 30kg lighter :thumbsup: I still think there is a god chance of cracking them though
https://www.sau.com.au/forums/topic/172697-brake-duct/#findComment-3183478
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
