has anyone else had there car tuned on ve cos ive been in cars with lag but this feels different it could be set up.in the top end you see the torque drop of it was explained to me that its cos of the cams need to be bigger tuning in volumetric efficiency  calculates the amount of air that can flow throw the engine
Tuning in 'VE' is just a way of making it easier for the the tuner to make changes and see what is going on, so long as it is a competent tuner the end result should be the same - if any tune isn't matched to the VE patterns of the engine then the mixtures will be all over the show. So really all tuning is VE tuning, it's just sometimes more obvious than others depending on the software ;-)
  • Replies 539
would that be a fuel AFR like bondi beach as i saw mine starts high waves up and down and at the end it at around 11.6 instead of a straight line what im use to.
If the efficiency of the engine drops off your VE numbers will tend to flatten out and sometimes run backwards.
That torque curve says it all. Add some more boost if you have a decent controller with rpm correction at the point where the torque curve falls over (150km/h). Power will keep climbing and torque curve will stay flatter.
do you think that he is pulling my leg about the cams
Edited by WARLORD
  • 2 months later...
I'd be interested to see that curve - sounds a bit odd.
i have finely post a video up not the best but it gives an idea.
Looks like it goes well, hard to tell from clips but it seems on the laggy side to me though - could easily be wrong. Usually easier to tell when you can see rpm/boost. Enjoying it?
unfortunately i did not get a print out of the a/f ratio but it was as i said.lots of things are wrong,when it gets seen to ill post the report of things that are wrong.its not really enjoyable knowing it could be better after spending $1460
for eg
flats spots in the rev range
one value set up for anti lag instead of a map set at 23psi which is way to hi
boost setting set up wrong so that the car was spiking at 29psi every time
knock threshold not set up
if car stalls its hard to start
fouling plugs
so once i gets fixed im sure it will not be as laggy,im also getting a haltech wideband for the Ecu.
Edited by WARLORD
Clearly they can't tune! Going elsewhere or staying with them?
here is his map for the anti lag lunch control,
the other pics is how the map should look (it works it may not be the best but it works good)
Edited by R31Nismoid
Lets just keep the tone of the posts down in here, it's treading pretty closely to the line (and i've edited out some of the comments made thus far).
Be mindful that anything you post is only ever one side. Agree with it or not, that's how SAU is and needs to be to survive and keep the legal bills to a minimum around here
  • 2 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
