Hi Guys
Sorry to bring up an old thread, but i need a bit of help.
I will be installing my nismo 555cc injectors and setting up my power fc for the injectors in the next couple of weeks (running a HKS 3037 Pro S and all the supporting mods) before i book it in for a tune, i have worked out the injector correction and injector latency correction numbers that i need to change in the PFC, can somone please comfirm for me that these are 100% correct? :)
"INJECTOR CORRECTION"
- Formula = stock 370cc divided by nismo 555cc = 0.66cc x 100 = 66%.
So i would go into the power fc and change the INJ correction to 66%, correct?
"INJECTOR LATENCY CORRECTION"
From what i have found the latency for the nismo's is 0.71msec and stock is 0.52msec
- Formula = nismo 0.71msec minus stock 0.52msec = 0.19msec
So i would change the INJ Latency numbers for each injector to 0.19msec, correct?
Hopefully this can help people in the future that are looking for the correction numbers :D.
By the way, someone should sticky this thread!!
Cheers
i did not check your maths but the theory and formula's are correct.
therefore if your maths is correct you are ok to go :rofl:
deatschwerks 450cc RB25det sidefeed injectors
Min Open time (ms) max idc 6v 7v 8v 9v 10v 11v 12v 13v 14v 15v 16v 17v
1.1 94% 5.89 4.48 2.97 2.25 1.88 1.73 1.46 1.37 1.25 1.12 1.09 1.02
deatchwerks 550cc RB25det sidefeed injectors
5.88 3.50 2.62 2.07 1.80 1.56 1.42 1.32 1.19 1.11 1.07 0.95
I'll check mine, I have 555cc Nismo's running.
I found anything under 0.30ms and I couldn't do a thing.
They were really hard to set.
You can have my settings if you want, they seem to work perfectly.
I think its 77% and 0.44msec. I'll double check on my way home this afternoon.
Sounds good :banana:, would be good to have your settings just incase mine dont work when i put my numbers into the power fc
Any idea why yours only work on 0.30msec? did you try the 66% and 0.19msec (using the formula in the power fc FAQ) before adjusting them yourself?
Is anyone else using nismo 555cc's able to go into there PFC and check what settings they have theirs set to? would be a big help!
Cheers
  • 3 weeks later...
I just finished installing my nismo 555cc injectors, i set up the injectors settings in the PFC like this: injectors correction = 66%, latency correction = 0.18msec (when i worked this out i came up with 0.19msec but the PFC latecy correction only goes up in 2's so i had to choose either 0.18msec or 0.20msec, i tried both and they didnt seem to be much different).
Started the car and it seems to run ok, i havent driven it, have only had it idling, it seems to idle "ok" but it is a bit rough, does this sound normal? is it just running a bit to rich? it dosent seem to smell overly rich.
Im dropping my car off to the tuners on monday so imtrying to get everything running the best i can so he dosent have to spend to much time stuffing around with it.
I got this figure from Google as i wanted to get the 555cc NISMO injectors for my GTS25t as well. Latency is 0.75msec. So settings for my Apexi Power FC are calcutated as such;
370 / 555 = 0.67 x 100 = 67%
0.75 - 0.528 = +0.222msec
Something like that.
Edited by teng
I just went out and started my car up again just to see how it was running, took two goes to get it started, still idling very lumpy, also it is now "spitting" lots of white smoke out the exhaust and smells super rich, almost like its just spraying pure petrol out the exhaust, it dosent idle to bad just a bit lumpy and rough, took out #1 spark plug and it was a little wet and smells of fuel.
Will the white smoke just be from it running way to rich? i always thought if it was running too rich it would have been black smoke, the smoke dosent smell like oil at all.
I think i might just leave the settings how they are now, even though its not running to great, im sure my tuner will be able to sort things out.
ok well i'll tell you my experiences...
I was using the default setting for what should be correct for the nismos 555ccs: being 66.5% and 0.18ms.
my car (r33 rb25det) was running way to rich so now im still running 0.18ms latency but 60% injector size correction. i once read that the factory injectors are 340cc not 370cc.
has anyone ever actually measured them??? or got this info from nissan?
Just had my car tuned a couple of days ago, he left used the injector settings that i had already set up in the PFC.
So just to clarify for future rb25det owners in the process of setting up their PFC for nismo 555cc injectors, use these settings, just like shown in the PFC FAQ
INJ correction = 66%
Latency correction = 0.18msec
Hope this helps people in the future!
Cheers :thumbsup:
  • 1 month later...
So what would be the correction for:
Going from 555cc to 740cc Nismo?
ignore the fact you have 555 and refer to the simple formula divide the original injector cc by the new injector cc. In your case 50%
  • 4 months later...
hey guys
i finally have some nismo 555cc injectors for my R32 gtst with rb20det. I am running a remaped ecu at the momment and will be changing over to the pfc pro i have laying around and these injectors before i drive it most likely to godzilla motorsports for a tune.
I am trying to work out two things so i can drive it there. What the new injector correction and latency is, and also if i need to add a gtr resistor pack when i install the injectors. I am only second guessing things because i noticed they have the same part number as the 555s for the 32 gtr. I purchased them from greenline and they didnt say anything about needing one but i didnt ask either.
I have read thru the pfc faq (thanks paul), and from what i can work out the correction and latency is something like this:
Old SIZE / New Size = Correction
New Latency - Old Latency = Latency Correction
So i think rb20 stock is
260 / 555 = .4684 * 100 = 46.8468%
.? - .71 = ?
So basically i dont know the latency for the nismo 555cc injectors when they are for the rb20det, i think most of the info in this thread is for the yellow rb25 ones :rolleyes:
Cheers guys
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
