  • 2 months later...
  • 3 weeks later...
  • 4 months later...
  • 2 months later...
  • 3 months later...
99 R34 GTT
13.62 @ 110.37mph. 60 ft = 2.55 (1/5/2010)
Was at Calder park for the first time. No past experience and need some practice with the launches. Also running street tyres 235x17 front/back.
Have been told that i should be comfortably making 12's. Running 18-20psi boost, 263rwkw@130Kph, 1045.5NM@90Kph.
Stopped with the runs once i couldn't reverse out of the burnout..think gearbox ok as no issue driving through 1-4, 5& Reverse no go when in gear. No crunching or bad sounds. Told it could be gear selector fork bend (think i said it right). Hopefully back on track in a few weeks.
^ Thats MPH is way to low for 260rwkw.
110mph = around 220rwkw.
110mph is good for around a 12.9/12.8 in a R33 on street tyres (you'll need a 1.9 60ft)
Yeah definitely. I had too much wheel spin in the street tyres. I'll be out with semi-slicks next time which should improve 60ft and time considerably.
  • 2 months later...
  • 3 weeks later...
99 R34 GTT
wat?? 13.6sec??
Im going heathcote this sunday and im hoping for 13's, and im doing only 180rwkw.. lol
  • 4 weeks later...
10.24 at 144 mph and a 2.2 60 ft ongoey r32 gtr james vosilaitis
http://www.fullboost.com.au/records.php?class=10
also id like to mention that this was achieved on street tyres ,thats why the 60 ft was shit
Edited by turbo rxp
  • 3 weeks later...
14.9sec @104.14mph on a wet track at heathcote. Only get to do 3 runs.
Looking for a mid 13's this weekend. And some better tyres.
yeah you should be able to get 13 OK
i was able to do 13.7 with 105mph with a crap diff
so if you have traction and a good diff youll be fine
yeah cool man. Will let u guys know after the day.
Need practice too. 3 runs wasnt enough for my first time.
And being wet doesnt help either.
