  • Replies 108
Same as on first page but updated 11/6/03
Updated above.Friday 13/6/03 is the Date.
Venue wil be:
Greater Union Blacktown Drive-In
Address: Cricketers Arms Road
BLACKTOWN NSW 2148
Move will be a double feature!
Field 1
First movie starts at 7:30pm (8-Mile is on 5th to 11th June, not sure on the 13th)
2F2F Start time is 9:40pm
Cost $10. (No EFTPOS facilities)
BYO grog!
Attendees:
Majanal + Jody
Duncan and Kel (I assume you will be using the same car and only one spot?)
Driftn 180
B-Man
Carlo + Toshi
Ricky B
ndr + Mel (and Monty?)
fatz + Dom
mmmgtir
PuppaDuck
RXB05S (thanks for organising us the discount mate)
Kinks
elcano
RedGTST + g/f
Blitz
Airzone + A lot of people in his car.
Prank + Bec
Jimbo
Tex
Marty + Fiona
Jon (Stenno)
xzotik1 + one mate
= 21 cars... rice! (Might be 22 as Kel refuses to ride in a neon Skyzer!)
(are the bottom guys still cool with going to blacktown?)
Maybe's
a5h (probably)
Silver-Arrows
Tex
Croatian R33
HSVKLR
Gotta get your names onto the top list asap guys.
Originally posted by SW20-GT
B-Man........
you and Dan have the dirtiest minds on this planet!!!!! well... maybe not but UR STILL DIRTY!!! :talk2hand
:cheers: Thanks man :D - i'll take that compliment !!!
Cheers,:bahaha:
Originally posted by HSVKLR
I may not be coming either guys - wound some boost today and wiped out the whole passenger side suspension assembly (control arms, hub (bent), radius arms) on a gutter.
If i can get up and running before friday ill be there!!
on a double demerits wekend too! :D
That sux dude... My bro did the exact same thing in one of my old cars... Except there wasn't any boost involved...
Call me stupid, but there's something I want to clarify first... I've never been to a drive-in, so I've got no idea what the normal go is.. I assume they don't mind us cranking over our engines for a bit during the movie - for the sake of our batteries... I had to push start my skyline yesterday because I had the cd player on for a few hours (as well as a couple of other things) while doing some mods...
I might come but we are going to bathurst the next day yeah? For those who havent seen it, it is a little dissapointing. I wont spoil anything but if you like skylines you will see one for about 10 mins of the movie.
btw, where can I get rice sticks (neons?)
