Hey all,
well with these cold mornings ive loved driving my car... although the colder it is the higher my Autogauge Boost Gauge reads... it looks like its hitting 19.5 (cant really concentrate on it or id end up in the other lane).... where as my Profec is set to 18psi and never goes over 17.9 or there abouts.....
now my EBC is attached to the Fuel Reg, and the Autogauge is attached to the stock outlet on the intake manifold....
so which one would you trust.... im thinking my EBC, but just wondering why my other gauge would read higher?
THanks Yall
https://www.sau.com.au/forums/topic/176874-which-boost-gauge-would-you-trust/
there is always going to be some discrepancies between different gauges. essentially they are both reading from the same place. just because the ebc is digital doesn't mean it is mroe correct. the map sensor may not be calibrated 100% correct. but then a needle guage isn't as specific when you read it. it depends on what part of the needle you read from and how well it was calibrated also. i would probably say the ebc though.
The Autogauge is an Electronic, Smoked Series.....
But im pretty sure the EBC was reading the same to the boost reading on the dyno now that i think about it.......
lower values its spot on just when it gets high it becomes inaccurate....
But $400 vs $90 is a big difference in price and quality IMO
unfortunately they are pretty crap, but what do you expect for $90 :domokun: i thought it was auto gauge from autometer but they are also average.
Get guages which have an stepping motor in it.. such as defis, pivots.. etc.. They are more accurate!!
I got a pivot one myself.. love it!! looks so much better!!
plus mine is built in electronic guage.. no need for a control unit..
but dont copy me now lol
Edited by siddr20
Now im in the same boat here, bought an Auto Meter gauge new Ultra series 2 1/16" and it says im hittin 7 psi low boost and 14 on high but stock gauge reads around 6 low and +7 high, now i'm running a supposed stock r33 with an 3' turb back with dump and pod filter, i noticed that my ECU seems to be an Nismo havn't pulled it out yet could this be the culprit?,
oh im running stock intercooler too, going to start a new thread and ask.
i also started noticing this today. got a sotck GTST seires 2 R33 running stock boost with only cat back exhaust. my stock boost gauge shows on full throttle running 5-6psi but my Apexi boost gauges shows 0.5bar (which im pretty sure is 7psi am i correct)
so imguessing my stock boost gauge is buggered??? or theres something wrong
the stock boost gauge on the dash does not show numbers in PSI, it has a different measurement. mmhg or something?
ahhh ok but what i ment was the stock boost gauge shows -7 0 +7.
-7=vacum obviously
0 and +7 is boost so on a stock r33 that +7 would be full stock boost so when you put your foot down at full boost needle should be at +7 yes???
mine only goes between half way between 0 and +7.
iv been told the +7 is 7psi but like you said the stock boost gauge dosnt messure in psi something different so im confused.
this goes out to r33 owners. does you boost gauge read all the way to +7 on open throttle???
my Apexi boost gauge shows 0.5 bar on open throttle so im guessing thats 7psi. am i correct?
No, if it's hits the +7 on the dash/standard gauge, that's more like 14psi
Its hould only go about half way for 7psi...so it's all good :)
BTW, i got a 2nd hand Blitz mechanical gauge of ebay deliver for about $20 and it's sweet as ! ;)
Its hould only go about half way for 7psi...so it's all good ;)
BTW, i got a 2nd hand Blitz mechanical gauge of ebay deliver for about $20 and it's sweet as ! :glare:
thanks for that dude. that clears up everything WOOT
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
