Awesome times, Slicks or semi slicks??
265-17 Dunlop slicks Mathew. Car is only 2WD so getting traction out of corners on semi-slicks would stop me from getting those times. They were used slicks and were definately not as good as they were when new. Even new they couldn't put the power down properly so I now have a set of Panasport 17x12 rims for rear and 10's for the front so I can run some Sports Sedan 300x17 tyres on rear. With the extra traction from those Im expecting to better all times.
I'm also halfway through fitting up a dual master cylinder setup with balance-bar and in-dash adjuster so I can play with the bias. Also looking to improve the rear brakes as currently they are just stock JZA80 Supra.
Right - I feel I can put my car in here now even though it is still street registered. :)
1999 R34 GT-R V Spec. The whole focus of the cars build has been towards winning the Dutton Rallies. And finally on the weekend we were able to win Dutton Vic :)
Car has a built 2.6L with twin 2860-5's. Tein RS suspension, complete R33 drivetrain, half cage with side intrusion bars and a bunch of other goodies.
I agree 100% definatley the Nissan throttle body helping with the speed. Very impressive lap times there will look forward to seeing your car in action sometime soon. I hope i can match or better those times when my car is finnished (depending on driver skill) as it will be a bit demoralizing being beaten by a toyota little own a bright pink one. :)
Sounds good, which car will you be using? Im assuming its the R32 in the avatar?
You will of course be dropping the front tailshaft, right? :)
The gearing in the R34 6 speed is too short in 1st for the cone stuff at the Dutton Rallies. But more than that the whole gearbox in the R33 is much nicer to use than the 6 speed getrag. The R34 has that stupid 3.54 diff which was designed to give some rediculous top speed that will never be used but it also meant that even though the car had 6 gears there was "gaps" in the rev ranges at some tracks. The R33 gearbox / diff combination is just much better all round. I also have taken out the V spec diff and put in a non-v spec mechanical which has been tightened up. Much nicer than the V spec diffs especially on the skidpans.
1999 R34 GT-R V Spec. The whole focus of the cars build has been towards winning the Dutton Rallies. And finally on the weekend we were able to win Dutton Vic :D
whats involved with going that way, more so the tailshaft??
i've gone the oppisite and i have a 34 box in my 32 but i keep getting questions as to what i have done with the tailshaft
we had to moddify a R33 tailshaft into an R34 one. I didnt do it so I don't know the full story I just know the tail shaft is part of each one now. I know the standard tailshafts were the wrong length which is why the mods had to be done.
I am actually in the process of building an R33GTR for track use hopeing to have it ready for the indy ralley in oct but am starting to cut it fine on having it finnished in time I will be keeping that front drive shaft though.I will just be running semi slicks so with your full slicks that should even up the traction issue a little.
ok sweet i think thats similar to what i know about it also. joined the 32 one to the 34 and its the right length or something along them lines.
i love the 34 box tho! tho have only driven eastern creek
yeh good ole john loves spiting me.
Its pronounced "inspiring" mate :thumbsup:
I only came along to defend Pinkys honour ;)
Get your mates together and bring out the Nismo's to take back the crown mate ;)
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
