I'll show you in 3wks :banana:
Oh,,,I see,,,so we all have to wait,,,I'm quessing something light and small,,,something new,,,something using fibreglass,,,something not street legal.
Sorry but you can't use that engine to power you down conrod NAKED buddy.
Neil.
Getting there... bit by bit. Modified HKS manifold, came out really well.
Nice work man. The stock HKS welds on those manifolds are horrible. Every one I have come across has cracked in no time.
What turbo is that? What flange did you convert the manifold to?
Edited by Equinox
Thanks mate. Mine was majorly cracked from hitting the screamer pipe on the ground, so had a massive hole in it. It had already been repaired in other spots though, so I'd ay you're spot on with the welds.
The turbo is a HKS T300, so the flange hasn't been converted. It was all part of a kit, I just had the manifold repaired, and the wastegate location braced and moved from the bottom to where it is now.
I've attached a pic of what it looked like when I bought it.
Yeah, it looks to be the weakest link in the chain for sure. I want to run with it, see how it goes and if I'm not happy I'll be moving to a 3071 or 3037. I've got it here so I'd like to see what it can do.
It was previously running 241rwkw's on a stock engine, including stock cams. If it can do 270-280rwkw's with a nice fat spread of torque I'll be happy for the time being.
Alright, Roy wants some pics of where his wheels are doing duty now.... I didn't know of a better place to put them guys sorry!
This is my 32 gts-t in progress for tarmac rallies. They have recently become elligible for the late classic classification competition, and I'm hoping to be able to take the fight up to the RS Porsches and RX7's.
I purchased the car from Melbourne, it was imported under the 15 year rule, and set up for the previous owner by Jimmy Richards. It's pretty basic, really just cage and associated safety gear, suspension, 32 GTR brakes and exhaust.
I've since added a power fc, boost control, new exhaust and a few other bits and pieces. I have a bunch of other stuff to go on, from HICAS remval kit to GTR wing because apparently it's a measurable improvement. We're not allowed to go crazy with mods, but having a strong car that looks after its tyres and can be flogged mercilessly for 6 days is the aim. Hopefully this car gets to that level :)
33GTR brakes and 2-piece rotors, Ferodo 3000 pads all round. I like plenty of brakes :rofl: Note Roy's wheels all grubby n sh*t just to annoy him.
As it looks now;
Other side;
Inside;
Inside again;
New 3' system (rules now allow free exhaust after turbo, did have a nice 2 1/2" system on it in stainless if anyone needs one?;
Nothin crazy in here, although I was really pleased with the improvemnt after adding the tower shock;
Lakeside;
With my friends beautiful XT GT Group Nc car;
I really enjoy my racing;
They are your wheels now! :) The white looks great on the black! If it ever comes down south again we will have to swap seats. I have heaps of new gear to go on my car, which i hope mean i can abuse it at the track reliably for 6 hours, lol forget about 6 days :rofl: You will probably love the power of mine compared to yours, but no doubt yours would win out package wise
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
