A few pics from today ;)
Does anyone know what the module is i have taken a close up of? It is located in the boot in the opposite postion of the factory jack/tools location.
cheers :)
The is the unit that controlls the voltage to the fuel pump in a gtst. Basicly it stops the pump from priming after a few seconds if the motor is not started once the ingnition is turned.
Cheers
Ross
hey dane back to your setup....have you allowed for the remote triggering of the kill switch? I would like to put ours there somewhere as well but am worried about the cable routing to the outside. Needs to be near the base of the windscreen drivers side according to CAMS
We were discussing it before we decided on mounting it where it is, as it was originally going to go in centre console in front of the shifter but we were forced to move it somewhere else due to gearbox position. I think it should still be doable running it down the transmission tunnel, but we'll find out soon enough... hopefully it'll be fine!
Duncan, have you seen the latest batch of electronic kills? Was reading about them on the weekend and they are obviosuly more expensive but far easier to install and far more reliable then the cable type. They are also now cheaper then they used to be
Duncan,
it can be done with cables mounted next to the window on the drivers side, you will need a long drill bit but it takes it directly into the main cabin under the dash. I can send pic of my old slugger when i get back to dubai if you like. I then just ran the cable to the battery box located where the pasneger seat used to be so i can turn the isolator with my hand rather than two cables. Also works for the fire system too.
yeah chris that's where we've always put ours in the past, its like nissan wanted us to put them there lol. But it kind of restricts you in where you can put the kill switch.
in the production car the kill switch activates a NO relay right next to the battery, the standard fuseable link plugs into it. It works fine but if you forget to kill the switch the relay drains the battery.
so in the new car I would like to put the kill switch on the tunnel and cut the actual main power feed - but I'm still worried about the cable pull.
Roy - I've never had any trouble with the mechanical switch an electrical one sounds worse not better to me. I have seen people have the switch key wear out, I should carry a spare one around like Neil does.
Any more pics of your boot lid? :blush:
Is it all c/f or is it fibreglass with a c/f layer?
it weighs 3.5kg and is fiberglass with carbon fiber top layer
boot lid and boot lid mate, flat on top and flat down the back.... if u really need photos go to www.clubhighrollers.com and search GOT04
stay safe
pretty sure bolt in cages are still legal, aslong as you get a cams approved one. From what i've read, the japanise cages run smaller diamiter piping, but run thicker walls.
Yep, I have a CAMS approved bolt in. It's just the jap cages that won't pass
in particular the bends around the dash take all the strength out of the front arms of the jap cages. and like Ben said the diameter on them is too small for cams rules too.
no wonder they are cheap to buy second hand....you can be knocked back by event scruitineers for a non-complying cage, even if no cage is required for that event.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
