Hey Nick are they Benos custom Tein RE's?
I'm actually not sure if he played with them Jason... I suspect not... we both agreed there is too much rear spring in the car, the back end jumps around over some of the bigger bumps... but that's what you get with 10kg/mm springs front and rear... they are fairly old and could do to be pulled out and possibly rebuilt so I will get him to work his magic on them one day...
Nice Zed... must be fast, its red! :/
I remember reading thaty the short wheelbase Z was quite twitchy, do you find that's the case? Or have you not driven it yet?
Its a weight distribution issue.
2+2 is 48/52
2 seater is 45/55.
A street car on the track could be a handfull. I know last time I went to Winton in my street car. I pulled the stereo equipment out of the back. Big mistake. It was a handfull, but very easy to drift around corners. :D
As I said before, if you can get the weight distribution right it shouldnt be any worse than the 2+2. In fact it ishould be way more nimble.
So take as much weight as possible out the front and between the axels and move as much as possible behind the rear axel. Problem solved and a lighter car. IMO 50/50 is obtainable.
yeah I like 2 seaters better as well. Looks better balanced and more like a 240z style car instead of a BOAT like a 2+2.
Edited by Tektrader69
It doesn't need to be perfectly balanced to handle. You can use any number of tricks to fix it. Most people find if they can run more rubber at the rear then the car is balanced better & is quicker with more weight in the rear. Weight distribution being roughly proportional to tyre width ie not 50 -50.
Here is a photo of my bucket o' lard to illustrate the point: :D
Agreed, Street car has 265/35/18's rear and 235/40/18 front. Is very twichy ride without weight in the back. Dont think the variable rate Eibach/AGX suspension helped it much on the track.
Track car has Hoosier slicks 245/40/18's front and rear. Will be interesting when its done see what its like. Suspension is expensive Proflex monotube coil overs with whiteline sway bars.
BTW your R32 looks pretty FAT with that rubber ;)
Thanks Steve-o funny you should say that it is bens old motor he gave it a good freshen up for me when i got it from him. We had a good talk about what we wanted from the motor and its all about the response so we bind the GT45 and went for the T04Z and a stock plenum we will still be looking at about 470rwkw when its finished.
  • 3 weeks later...
not really, should get the car back around Targa. Depends if the cage builder's Targa car needs time. The engine is at peices at the engine builder, we'll probably be asking them to start putting it back together soon, so we can drop it in the car when it's back with a cage
okay posting for phunky_monkey... please note I did not build it and haven't gotten it to the track yet but hey, what else am I going to do on a Friday
Previously owned by Nathan from the SAU Vic club
'96 R33 GTR, built by Ben @ Racepace many moons ago so is a bit old school
Built motor with Tomei gear, pistons, big cams, springs, lifters etc etc... with Benno custom sump and catch can etc
Trust T517Z 8cm turbos
Trust FMIC, Radiator and Oil Cooler etc
Tein Type-RE Coilovers etc
Harrop 4-pot Calipers, 355mm 2-piece Rotors
BBS LM Forged Alloy 18x10.0 +20
and a bunch of other supporting parts... makes 360rwkw @ 20psi
Is pretty loud and lumpy and generally not as refined as recent Racepace GTRs but I love it... it has personality :D
and it gets me to work really quickly lol :P
soon to be at a track day near you :P
Excuse the filth, had been driving in the rain before this...
Awesome gtr, what a package!! :cool:
I would give my left nut to own one of these!
unfortunately I don't take nuts as payment lol
I love your FC too dude! very nicely put together... maybe we need to give each other a ride sometime:)... actually that sounded kinda gay but you know what I meant lol
another pic for no good reason
i thought i should formally introduce myself as i just jump in and out of SAU topics all the time.
This is my car i have built up over the past 18 months and counting. best thing about it is i have been racing/using it while building it.
late 08 i took delivery of a stock r32gts with a RB25DE
i transfered all the stuff i salvaged off my old burnt out shell.
main stuff from this was a RB25det Gear box custom tail shaft and auto diff. also a lot of suspension bits. sway bars and adjustable arms
then i sat and pondered what to do with the engine. sell it and get some thing else or turbo it?
after consulting a few people who had had good outcomes with RB25de+t i decided to bolt one up.
i sourced a r33 turbo manifold, i had a stainless split dump pipe, and i robbed a spare Rb20 for the oil and water lines. A r34 neo turbo fell into my lab by chance and i got another cheap R32GTR inter cooler and cheap IC piping kit (just done the same thing to my old car)
during the engine freshen up i got a Sparco seat recaro bolt in rail and a brand new harness ready to hit the track.
while all this was being done to the car i was trying to sort out the best possible way to go with the ECU while maintain a modest budget.
the best option turned out to be the good old Apexi Power FC for a RB26dett. i sourced the wiring diagrams to modify the PFC to run on my engine and also picked up some GTR injectors and an MR30 resistor pack.
i got the car running and out on the track for a practice day one week before the first round of the 08 Drift Australia round in Tasmania. the only fault with the car was blowing IC pipes off at only 10psi :down:
I made it the following weekend to Drift Australia to compete in super drift where i qualified 9th and finished 11th in my first ever competitive outing.
the next outing was round 1 of the Tas Drift series where i had zero dramas with the car all day and finished 6th.
like most budget builds what ever i can do my self gets done so amongst all my horse trading i ended up with a Z tune style bonnet vent and after may hours my best mate and i made it look like it was meant to be. in the process i cut the front off and fitted a Nismo splitter to cover up the cutting job.
this bonnet while not being much lighter than stock has never seen engine bay temps higher than 95deg even club daying during summer.
between the next few rounds i got the car dynoed as it had only been ruff tuned by a mate up until now. the dyno netted 194rwkw on 10psi but was backed off due to a slipping clutch.
new clutch in and a few more events achieved but nothing real major was done to the car just the usual maintenance.
i ended up finishing 4th in that Tassy Drift series for 08.
round 5^^^
then i thought id take a few months off and this happened
and i made a new cluster
and a switch pannel
then i took it stripped down to a club day with some new 17" rims sporting dunlop semi's
i like to build things so i built a CAI and air box
after 12 months of drifting the front end was a mess so i got some GTR guards and a GTR bar and a Vail side front lip which has now been repaired 3 times. :thumbsup:
brand new coil overs were the only thing the car really needed so i got some of the new Pedders ones
and then i also re-trimmed my dash in seuwed to stop reflection off the dash.
i was asked to do the drift demos at power cruise in tassy so the car was rushed back together once again and i made the most of it.
After round 1 of the 09 Tassy drift series i decided that it was time to take a more serious approach and get a roll cage so i can move up maybe to circuit racing
a Bond Roll Bars weld in kit was ordered and has been my latest project for the car.
it has taken me a fair bit of time as i do all bar the final welding myself but i am pretty happy with the end result which is 2 bars off being finished
while the cage has been going in to keep myself sane i have upgraded the front brakes to R34 GTT calipers and rotors.
only one slight mod was needed to fit these and i am keen to see how hey perform over the stock r32 things. tech note that they are 30mm bigger diamiter rotors.
sorry if this has been a bit long but hopefully some people take some ideas from the stuff i have made and done.
thanks for reading Damien
Wow!
Damien - that is an awesome write up and build mate!!!
Done a bloody good job!
The air/headlight intake is pretty sweet!
Oh, and the dash is cool set up!!
Again - awesome work!!
What sort of circuit work you going to get into?
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
