right click, get the properties of the pic...then insert it between :P
for instance
http://sphotos.ak.fbcdn.net/photos-ak-snc1/v271/10/86/1320006294/n1320006294_30026626_9359.jpg' alt='n1320006294_30026626_9359.jpg'>
Did you do NSW Dutton in that year a few years ago?
No, Just opens up at a set pressure eg 1.2 bar the valve opens so manifold pressure cant go any higher, no you dont have to have a wastegate but its a good idea to run them to stop the turbo over speeding.
The Production race cars like duncans run them as a requirement so they cant run more than the factory boost pressure.
Nizpro used to just run a pop-off valve setup and no wastegate back in the early VL turbo days, with success.
No because the full force of exhaust gas is running through the turbine, and with minimal restriction on the comp wheel, than the turbo will spin way harder than what it needs to for the required manifold pressure.
It may help minimize spool time if you had lazy internal gates, external gate will be no different untill the gate opens
Sorry that does not make sense to me, if there is less air there is less spark,less ex gases?
the point of it is to stop to much boost not to decrease power.
if your car runs on 8 apples. the turbo spools up to 8 apples then it finds that A) the waste gate wont let enough apples past or B ) you have restricted boost for a comp.
in point A the turbo keeps spooling to 10 apples and pop goes the engine or you add in a pop off valve and it lets 2 apples out keeping the manifold pressure at 8 apples. its not designed to let 10 apples out of the system only a few so it just regulates the boost.
with only 8 apples in the system the turbo still trys to produce more but it can because they are being let out.
hope that helps but its realy a question for the forced induction party not the show us your racing machines people.
My r34 at yesterday's track day.
Had my ass handed to me by a pack of evo's. 6th in class D, out of 8 cars. If only having the prettiest car took seconds off your lap time....
Wow, what refreshing honesty! Nice post mate :)
Very very nice looking car too!
'course it's nice! it's my old car. ;) ;)
man you are looking after her mate. it looks stunning. :) and yes way better looking than any poxy lancer.
Those crappy Falken Azeni's you are running aren't helping your cause. If funds allow, try to get some newA050's or even RE55's under that R34 and look out EVO's!!
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
