I'm not married, but will gladly get hitched if it means handing her over to you will solidify me a steer in the Rad :)
:cool::blink:
Me either! :devil:
Haha I recall you also offering me a go in your car some time ago if ever I was in QLD, so the offer is back at ya mate ;)
Im up for car swapping too Dane! I mean, who wouldnt want to drive the red wiggles car!
Haha I really should have a key party, I think I'd take home the prettiest girl in the room... if only it had a key.
Yoki is realeasing a true man's tyre soon, 295 :devil:
That's my aim!
Who needs geometry when you just have an excess of tyre! :blink:
WOW! That's insane. Prob be hard to make a 295 work on a car that light without the aero of Berry's 34.
Why spacers? Do the 10.5s hit the suspension, or are you two whacky kids just got track on the brain?
Yeah my 18x9 +22 RS's nearly hit the suspention up front with 235 tyres! I'm amazed that you fitted your 19's on your 32 Ben? Did you put em on the front or back?
You got it Dane :devil: Feel free to bring some of your hot women too you big hunk of spunk! :cool::blink:
Russ, I only put one on the front..... farkin hectik. iPhones take awesome pics....
Front, NO spacer, with a 285/30 tyre;
Have you trial fitted rear yet?
Edited by Marlin
LOL, yeah maybe, but I plan to make the body actually go over the wheel/tyre so them they'll hate me again :blink:
Least it will go round corners then.
but needs a set of wheels like this to go with the truck turbo :devil:
Brus aren't you supposed to wedge a credit card between the tyre and the bodywork?
this is probably as bad a place as any to ask - what do people know about 5Zigen wheels? up to the job of bouncing off kerbs?
We should talk Russ, see eachother through this :P
I'm thinking +15 with a 20mm spacer.... am I being silly do you think?
Where can we buy SLR5000 type flares for these things?
Yep I was thinking the same. Perhaps 15mm spacer if possible.. I was hopeing to get them under pumped GTR guards front and rear... Don't really like bolt on.
My next step is to put some 265/35/18's on my SL's and trial spacers. 20mm is most likely. No time atm though.
If it's a silly idea then that makes 2 of us haha. Check out my fb photo's when I trial fitted with 25mm spacer (no tyre)
yay this is my kind of topic.
get yourselfs a copy of the latest HPI. it has a s15 time attack car from J pan that was featured on speed hunters a while back. they just used the stock guards but spaced them out about 50mm with some bracketts. instant wide body. as always it could have been done nicer.
also not sure if either of you guys are running them but r33 lower contol arms will push track out moreso.
if you get much wider than a 10inch at +15 you will be getting scrubbing on the fire wall and chassis rail. i have 10 +15 on the front of my car with r33 lca and modified lock for drifty drifts and there is rub marks every where. i know you guys dont need ooooober lock but its worth considering.
oh and 10 +15 fits a gtr guard perfect so you can go a bit further and roll the guards.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
