eta to skids?
Collecting new exhaust manifold and newly modified rear turbo housing this week, then need to install motor and work out oil pulley size and order belt to suit. Then the tiniest bit of wiring, a tune and the skids. Before this time next month would be good as that's when the first Sydney meet I want to race at is on. :banana:
But then this: Rd 3 – May 18, 2008 - Compak Attak, W/Syd Int. Dragway, NSW
  • Replies 843
Posted Images
sick moit
just make sure u dont break it before august for rd 4 :down:
Picked up the new manifold and modified exhaust housing today. Both the manifold and exhaust housing have been coated with the latter being modified to accept the 50mm Turbosmart Pro Gate. They look sensational. Leigh from Extreme Turbo Manifolds does exceptional work! Couldn't be happier!!!
Completed assembly:
Collector:
Exhaust housing modification:
If it has this plate, it rocks!
Beat that!
Freshly coated:
It's very shiny now but I wonder what it will look like once it gets very hot a heap of times. We'll have to wait and see.
itll go fairly dull white, not yellow though. the stuff on a mates housing hasnt flaked either
Yes it has Shane. Its just starting to flake on the underside of the housing closest to the manifold. I am surprised it lasted as long as it did.
Take plenty of pics of it while its all shiny and new Adrian. It will soon turn to a much duller silvery grey. Looks bloody magnificent as it sits.
aargh i see, well atleast it hasnt flaked the spots where u can see :D
ah i remember ur car in a magazine (2rismo). dude how the hell does a stock turbo flow enough air for 300kw plus atw when its rated at around 300hp?? and ur motor served u very well!!! mine was making 280hp atw with stock turbz @ 13psi and the no1 cylinder rod spun a bearing and the rod snapped!! ggrrr oh well ur like me n fix things properly haha i got a fully forged motor with greddy intake man, gt35 with 6boost manifold and turbosmart gate, also microtech computer and all supportin mods. cant wait till the engines done ye ha!!
Hi Mate. The stock turbo never went anywhere near 300kW at the wheels. When the story in HPI was written, the 300kW comment came from me being asked how much power I thought it made to run 120mph. With its weight at the time and the terminal speed, I came up with a figure of just on 400hp at the engine - I converted this to kW for the benefit of HPI and that was that. The most the car ever made on a chassis dyno was 265kW (see attached graph). Without the nitrous, the car made just over 190kW (255hp) at the wheels which is about right for a maxed out standard turbo on a half-decent pump fuel tune. (I know that others have made more than that by 20 or 30kW)
Good luck with the rebuild, mate. It sounds like it should be a good thing. Make sure you take it to the track.
Adrian
tell the truth, you had a 300 shot in it ;)
Lol!! No, but jeez I wish I'd had the presence of mind to predict the engine letting go - I may just have given it a couple of hundred instead of the 100hp shot.
Are you going to use the NOS shot with the new setup?? Again, I suspect this is going to be a damn fast car soon.
What was the reason you went for the gate on the housing? Also, did the manifold get match ported to the head? In the pics it seems as though the exhaust ports are very round, doesnt seem to be the typical shape?!?!?!
I sit back and think of your car back in 2000 when it was sitting at BD4s and was getting punted at tracks with corners ;)
lol yeah a sad decline. I'm working with Paul that originally owned this car at the moment - he's currently got a golf gti and has had about 5 cars since he sold this one - I reckon he is still missing it
you wont find a better way to get optimal boost control, it will literally cut off as soon as the gate opens where most spike then tapper back down
looks like a killa setup your peicing together dude, cant wait to see the results
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
