hey guys, just bought a POWER FC. I was wondering what you guys think of them, and whats your experiences....ive heard nothing but good news...i actually have a MICROTECH ltx-12s which are a fantastic ECU but not good for economy, which my car is daily driven so its essential. I also like the user friendly features of the pfc...
cheers....
Ryan
https://www.sau.com.au/forums/topic/178189-to-people-who-have-power-fc/
I think it's more who tunes it than what type of computer it is. Being so common there are lots of places that can tune them.
The PFC is good in that you can easily check if there is something a little unusual going on. Another big plus is that it lets you know if there is excessive knock, maxed out injectors and i think AFM, through the dash light. So you can instantly back off.
Congrats on getting the power fc, should be picking mine up end of this week or next week. Is it true you need to upgrade your AFM when you plug in a power fc? I realise that it's a good upgrade to have done anyway but is it necessary straight away?
Nope, but it is recommended as there ain't much head room on the stock one when you start modding, upping boost etc.
Almost always a 300ZX 80mm airflow meter.
Yeah, figured a z32 would do the job, just need to get my hands on one and so do a few other ppl on these forums by the looks of it. I think i've been told about $350 for a new one (i think it's new), anyone else been told better prices?
AFM guide from Paulr33
Rule of thumb for Air Flow meters RWKW & Engine BHP
------ ---- OD ---- RWKW ---- RWKW ---- BHP ------ BHP
No of AFM's ---- ------- 1 -------- 2 -------- 1 -------- 2
RB26 ------ 65 ------ 149 ------ 299 ------ 271 ------ 474
RB20/25 --- 80 ------ 226 ------ 453 ------ 376 ------ 683
Z32 ------- 80 ------ 255 ------ 511 ------ 415 ------ 763
Q45 ------- 90 ------ 302 ------ 605 ------ 479 ------ 890
Always run power fc's in all my cars and never had an issues except for a faulty knock sesor. We are going to be selling wolf ecu's through our store very soon and would also appreciate people feedback on that ecu. As far as I no its alot more tunable then the power fc but alot more complicated to set-up and for the driver to change basic settings etc.
Ryan
It's probably a bit much but i'm getting my power fc for $1450 through a shop. Been told i could have got it for cheaper through nengun or wateva but oh well, it's been paid for already anyway.
Isn't the afm for a rb20 and a rb25 different? I though one was bigger than the other...
rubzy, your not the only one man, i just paid that much...got it today. very pleased.
Hey ryanrb25, whereabouts you getn ur power fc installed? I'd take a wild guess and say boostworx cos it seems like that's where everyone else goes but figured i'd ask anyway.
Nope there the same only series two have 3 wire not 4. Install it yourself follow paulr33 guide then take it to boostworx and get shaun to tune it, there the cheapest and by far the best
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
