Hey PimpDat - I was there that day with the black Hummer and yellow Lambo!
Did you see the McLaren F1? Crazy!
Yeah ive seen that Mclaren around a bit usually down at the old Maranello motorsports shop, never heard it open up tho : (
Did you happen to see Sam Newman with a hot blonde chick? he came out of tower 5 like a pimp and got in the biggest boat at the docks lol green with envy!!
You look at that car and the first thing you say is 'love those brakes' hahah wtf?
You can have the brakes, i'll take the rest of the car :)
Hell yeah id have those brakes :)
Hahahaha, of course i want the whole thing - but come on, as if those brakes wouldnt make your gtr that extra bit special :)
Reckon you could fit in there, Baron?
lol, I'm not that big a unit! hey if I can fit in an alfa GTV with tiny kevlar momo seat (bolted to the floor mind you) then I reckon I'd give it a crack!
phunky, LOVE the murcielago. especialy in black (or is that raw carbon?) either way it's nasty!!
Yeah well I am just bitter because after doing the engineering sign off for the GT40 below I was supposed to get in & go for a drive. Let's just say I missed somewhat. Damn tupperware tractors.
The murcielago R-GT comes in raw carbon.. Not sure whether this is standard or just an option but there's a higher res view of it here: http://www.italiaspeed.com/news_2003/frank...go_rgt_103.html
well it is only 40inches tall after all! you need the one with the bubble in the top of the door for some extra headroom! Having seen you're pics though your a pretty big dude.
Well a Gurney bubble would only be about a third of the answer.
The pedals made it half way up my shins.
The other problem was there was no way known I would have been able to put on any corrective lock.
Why can't they make cars to fit proper sized people, instead of just scale models? :P
Unfortunately 40"s makes a GT-R look like a bloody people mover. For the record the 917K was even shorter. Damn it all.
Raw carbon mate, and the thing is pure automotive porn!
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
