I saw me doing this today (attached).
Is the first time I've actually campaigned a Porsche in anger, and I didn't do too badly at all! It's not as Playstationy as the Evo, but by golly I highly recommend it to everyone :)
* for the trainspotters... its a 996 GT3 CS. Same car many saw lapping at Carrera Cup car speeds at PI last month.
Is AB's car.
They needed 6-drivers to fill the GT3/RSCS category for full championship points to be awarded, and only 5 had entered. So...
Weather was mixed, but I did well - as fast in the wet as some were in the dry.
AB is an excellent steerer - impressive handbrake skills - but there was a 993 RSCS that might pip him for 1st. I could be as high as 3rd - not bad for a hack :P
1.48's @ PI isn't Carrera Cup speeds - hell it isn't even Street GT-R speeds! :P Bring him to DECA and we'll teach him some lessons.
http://www.pcv.com.au/PorscheClubs/pc_vict...File/0803pi.pdf
(1.39.7 by the open class dude is moving however!)
I think this porsche might be sexier!! hehe
Was driving home from an exam around 1pm today and saw this weapon behind me on punt road. The thing was bloody loud and low as, had heaps of neg camber on the front and a serious looking cage in the cabin.
I'm pretty sure I've seen it at Sandown once before.
Yeah, you would have. He's part of the Porsche club, gets his stuff done at Weltmeister. It's for sale at the moment for around 150k... basically a cup car that is registered.
I want it...bad.
:wacko:
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
