How are peoples results using nistune for RB26s? If you are using it on your RB26 please post engine mods and results (dyno), can't see many if any in the RB26 turbo upgrade thread.
Are there any limitations when compared to other standalone ECUs (e.g. ViPEC, PFC)?
I'm using one on my R32 N1, no drama's at all.
Only mods on my car are a cat-back exhaust, pods, and boost controller. Of course being an N1, it has the N1 turbo's as well.
So far it's performed without a fault. No cold start issue, no anything really.
I spoke to a fair few tuners and in the end, for someone like me who is not going to be endlessly modifying the car, the Nistune was perfect. I'm trying (really hard :banana: ) to keep my car close to stock.
Price wise, can't remember exactly but it was less than $700 including ECU and dyno time.
Here's is a copy of the tune. We stopped at 276kw as the AFM's were maxing out.
https://www.sau.com.au/forums/topic/181930-nistune/page/7/#findComment-4528995
Thanks for the reply looks like a good result, very helpful, especially the note on cold start as these features are critical for a regularly driven car.
I would have preffered to keep my car very stock except I had the unfortunate experience of stock turbos failing and taking out the engine. So now i'm running a forged engine, 2860-5's but most of the rest of the engine is stock (dumps, front pipes, AFMs, injectors, head). Although in the future, once my wallet recovers (if ever) the aforementioned items will likely be changed to allow higher power - hopefully close to 380awkw eventually. So I am really curious to see if and how nistune will handle those types of changes - AFMs and injectors particuarly - whilst maintianing the factory ECU hardware. Anyone using nistune who has changed AFMs and/or injectors (especially GTR's)? could you please comment on drivability with these changes.
Keep the results and comments coming. :banana:
https://www.sau.com.au/forums/topic/181930-nistune/page/7/#findComment-4529038
My 32 GTR is dead stock except for K&N panel filter, nismo front pipe, catco 3" ceramic hiflow cat and apexi catback and adjustable cam gears (set for midrange torque): 199kw/290Nm at the rears .. it still needs to go back and finish the tune with my replacement EBC
https://www.sau.com.au/forums/topic/181930-nistune/page/7/#findComment-4535096
Hi there from London ..
I have the same question ->
"What ECU are you using??"
I was told there is no Nistune for the R33GTST ..
Cheers,
Andrew
I'm running a r32 (rb20) ecu and i still have all the VCT the only hick up was the TPS due to different sensors in the r33 and r32 gear boxes (when it is and isn't in gear).
Not a major hasle just got the boys at EFI performance to fix it up for me and problem solved
https://www.sau.com.au/forums/topic/181930-nistune/page/7/#findComment-4536746
  • 2 months later...
Interested to see how the vct works on rb20 ecu?
True most forget that small (but useful) feature :pirate:, the funny thing is ive had about 4 microtech's come through here lately done by a microtech dealer all had no VCT switching..... :) and the power graphs were shit house, you would see a few too yeah?
https://www.sau.com.au/forums/topic/181930-nistune/page/7/#findComment-4703042
was thinking of using NIStune to run a r32 gtr ecu on my vl turbo. aside from coils on plug and twin mafs what other features does the gtr have over the vl. could you install vl turbo base tune on the the r32 nistune board.
https://www.sau.com.au/forums/topic/181930-nistune/page/7/#findComment-4708850
that would be the easy way.
but the thoery was to delete the dizzy and run coil on plug, plus th gtr runs twin MAFs. two standard vl mafs would read higher HP than a single z32 maf and have better flow. and easier to upgrade to a twin cam head later.
https://www.sau.com.au/forums/topic/181930-nistune/page/7/#findComment-4709985
  • 2 months later...
was quoted $1150 for an R34 GTT nistune + dyno tune .. considering they're $260 seemed kinda excessive. What has everyone else paid for a dyno tune with their nistune ? Car's pretty much stock ..just the turbo back exhaust and a bit of extra boost (11.5psi)
https://www.sau.com.au/forums/topic/181930-nistune/page/7/#findComment-4859754
im also running nistune got it fitted and tuned for $750 at chasers in melbourne. my gtr makes 200awkw (check RB26 thread) runs bigger injectors, greddy ebc spec II and exhaust everything else is stock.
After the tune i seem to be getter better fuel economy. but at the same time if i push it hard i use alot more fuel (probably cos of bigger injectors and boost though).
https://www.sau.com.au/forums/topic/181930-nistune/page/7/#findComment-4859764
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
