Hello everyone,
I feel really stupid, but.. where is the oil filter ? and how I can access it ? I tried to look from underneath of my car (Stagea S2 if it matters) but plastic guard covers alot and car sits low so I was able to see much. Tried to put car on the ramps but again - she sits low and front bumper prevents her from going on the ramps. Can anyone point me to the right direction please ? :thumbsup:
PS Yes, I know, I know, fell stupid myself >_<))
https://www.sau.com.au/forums/topic/182777-silly-question-oil-filter/
LOL!
Drivers side of the engine block, about 2/3 of the way down. You WILL need to grow an extra elbow between the existing one and your wrist to remove it tho.
Haha! You probably seen it just didn't know exactly what you were looking for. I myself only recently did my own oil/oil filter change and I know it can be daunting especially when you don't have anyone to confirm what you're looking at.
It the cylindrical thing (usually blue) on the left side of the engine (if you're facing the engine bay) towards the bottom. You can access it from the top or bottom, I loosened mine from the bottom then took it out from the top. I'd recommend getting stands to jack you car on to if you're going to do a change yourself.
Hello everyone,
I feel really stupid, but.. where is the oil filter ? and how I can access it ? I tried to look from underneath of my car (Stagea S2 if it matters) but plastic guard covers alot and car sits low so I was able to see much. Tried to put car on the ramps but again - she sits low and front bumper prevents her from going on the ramps. Can anyone point me to the right direction please ? :pwned:
PS Yes, I know, I know, fell stupid myself :thumbsup: ))
Thank you for prompt replies, guys, I will look at it again, probably on Friday :pwned: I am not a mechanic but I've changed few oil filters in my life and done simple things with my cars before (probably most "complex" thing that I've ever done was changing a head on my Fal*on's engine but boy ! there are SO MUCH room there under the bonnet ! :thumbsup: ) What I am trying to say is that I know how oil filter (or, I'd better say, usually) looks like... :) - still, I was unable to find one (bashing my head against the wall)
JVP, there are different oil filter removal tools, I'got one.. well, it's sort of J-shaped. I will need fair amount of free space to use this toll. Or you are talking about something else ? Also, you mentioned extention, I've never used one before..
Any way, I'd give it a go again :)
my mate who is a mechanic by trade, has these really good ones that are like a claw, and they adjust to size of the oil filter, and on top of the handle, they have a connector for a longer extension bar. it cost him a bit, but its well worth the money. my guessing at the brand is snap-on.
maybe the car has a remote located filter???? if there are some hoses and an aluminium plate with fittings in it on the side of the drivers side of the engine block (located directly above the main crossmember) have a look where the hoses go an follow them till you find the filter.
repco do an AWESOME one! its got a 3/8ths square drive in the center and a ratchet mechanism that makes the 3 arms close over the filter. well worth it ! they normally come with rubber covers over the
arms .. and you sometimes need to remove those to get more grip
cost me $20 or something
Any way, I'd give it a go again :pwned:
keep going past the fuel filter and its there.. UNLESS.. you have an oil filter re-location kit!
its a fair way down towards the bottom of the engine bay and fairly difficult to see
Hm. Still unable to see "the cylindrical thing (usually blue) on the left side of the engine (if you're facing the engine bay) towards the bottom." :thumbsup::pwned:
Oh, ok. I'll try it on Friday (I hope). If I see nothing again then I'll put her on jack, remove the plastic sheild and have a proper look. "It's personal" :())) coz I feel really silly being unable to locate oil filter :D
you will piss it in ! get one of those tools.. a beer.. and follow down past the fuel filter and your in the right area.
mine had been put on by a rock ape.. and my whimpy IT hands couldnt budge it, but that repco tool saved the day.
I make my own beer so I have at least few dozens at home :D this is not an issue :() Repco tool - well, I'll try to undo that thing with my IT hands and, if I am not lucky, will jump on my workhorse and get the tool.
free beer? ! I'm in !
I make my own beer so I have at least few dozens at home :D this is not an issue :( ) Repco tool - well, I'll try to undo that thing with my IT hands and, if I am not lucky, will jump on my workhorse and get the tool.
heres a pic of it (its the big blue thing on the plenum side of the motor). this pic is with a 2wd sump on, but with the 4wd sump on its hard to see from underneath as it sits directly above the front diff housing and when u dump the filter off its gonna spew oil everywhere so sit some rags on the top of the diff housing to soak up the oil.
much easier to get at mine than one in a RS4 :(
Same here :D Should know cause had to do an oil change this arvo....oil filter tool I got has a handle which pivots side to side. Pretty sure I picked it up from Supercheap Auto sometime ago. It might help the RS4 owners get into those tight spots.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
