Regular Vs Premium
73 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Always 95ron+ If you use regular, try not to boost your car. The minimum you should use is 95 octane fuel.
Edit: I remembered you have a NA Skyline.
Edited by adam-__-
seeing as my line was designed to run on 100RON, i'm not gonna be a tight ass and run it on 91 or 95RON. it's only a few dollars extra for decent fuel ffs
bp ultimate or vpower racing :)
Edited by into oblivion
I just want to add that running your car on 91 octane fuel could give you less km from a tank than if you're running on 98. The money you save by running on 91 octane fuel is not all that much if anything at all when you're filling up your tank more.
In other words, you could get 300km out of a tank of 91 octane fuel, but you could get 350km out of a tank of 98 octane. Your engine is tuned to 100 octane fuel.
Edited by adam-__-
The BP up here (karratha) dosnt sell ultimate 98 they only have premium. Premium is the highest octane we get :yes: so i might have to get my car tuned to that. . . . or add tollune (spelling) every time
These cars were only ever built for the local japanese market. Japan as far as I know isn't aware of fuel lower than at least 95RON so none of their cars are made to run on 91RON fuel. Especially skylines and related cars. I believe japanese fuel is above 100RON so I'd recommend 98 as its the closest you can get in many parts of australia. Some states have 100RON (lucky ppl) although that comes at a higher price too. 98 is quite safe.
Depending on how your car is tuned, you may have trouble even with 95RON - i know my stagea pings a little on it. Its BP Ultimate98 for my stagea. Have tried shell vpower but wasn't as happy with it. Each to their own. :yes:
Offtopic a little - I often wonder how many people who buy these new hot hatches and other new aussie-delivered cars realise that they need to run on 95RON or higher??
Many of us are only vaguely aware that 91RON fuel exists, and yet most people out there are unaware there is anything OTHER than 91RON... :)
It doesn't matter who sells it, if its cheap, people will put it in their cars.
BP ultimate in my GTR, although i run boost 98 in my civic.. and it sure feels real peaky lol and gets more km per tank, so i might try run that in the GTR and see what i get on dyno to see if theres any difference
I only ever run BP Ultimate. I've found it to be the best fuel for me.. Never really tried Shell optimax though.
Previous owner used to use Caltex Vortex - he filled up my car with it prior to handing it over, car would ping occasionally at higher revs. BP Ultimate has not done this.
Seriously, how much do you really save filling up with cheaper fuel.... a few dollars. Then take into account less k's from the tank of cheaper fuel..... if you need that $5 you saved that badly, maybe you should buy another car.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
