On the weekly thursday cruise... sucks to all who didn't come :(
That thing was great! I can't believe he took the old road... I was all like "the stones and the twigs and the trees and the child and the car sickness and the pain and the glaiven"
Anyone have a spare $100k lying around... I want one too :)
Just checked my email, i sent them to jw at p1international.com.au
Oops
Resending now :blink:
So when am i taking a trip to Vic? If its in the next few days ill just burn them to disc and bring them!
  • 4 weeks later...
