  • Replies 68
well I figure since you drive it hard the dogbox is probably the smart choice for you. should be good fun when it's set up with the ign cut shift too. :P
i wish i was "allowed" to get one too...
ive got an Autronic SM4 with ignition cut shift too, coupled with a straight cut dog box would be heaven.
life is so unfair....or should that be "wife" is so unfair?
Disclaimer: although the above post was made on this account, it is not necessarily Paul that wrote it. Just incase Stacey is reading it.
what problems did you have with the ppg? and what bits needed replacing? did you have an ignition cut on the ecu for gearchanges? and did you use the clutch with it?
once this gearbox is in. it will be 70/30 track/street. thats what lary the laser is for :(
I broke 2 small input shafts, lay shaft bearing and need to replace 2nd gear. No ignition cut. I always double clutch on downshift on the race track and during slow driving around the street
Hey Guys still trying to get used to the box, just a qwuick question. When your just driving around normally(not on the track) do you find that you have to shift slowly and in 2 stages rather than just trying to smash it in like you would when flat out??
As it seems to be wearing in it is becoming a little harder to use around town.
Cheers guys talk soon
Matty
I found the same thing. The delay from shifting in 2 stages allows the gears speeds to match. I find double clutching on upshift (and down shift as well) on the street doesn't produce any noise what so ever during shift.....very gentle and graceful. Flat out driving there is only one joyful way of doing it as R33 racer stated. However I still have occasional trouble with 1-->2nd and often use the clutch for this. Does anyone have any special trick with 1-->2nd?
cool. yeah i would be getting the larger input shaft option. and all brand new bearings. and also will be making a spraybar for inside the gearbox to directly spray oil on each gear. havent quite got it started yet. either using a pump of the tailshaft or an eletric one.
do the straight cut gears suffer from lubrication issues in the gtr casing?
matty
when we are just chugging around, i have found being really forceful with the change is best. If i just lazily put it into gear in most cases it will chatter on the dog gears and feel rather harsh. best to be acertive with it even at slow speeds.
cheers russ cya soon , congrats again mate on the pittsworth win!!
Cheers guys was a good weekend. Yeah i suppose experience with it is the only way to figure it out properly. Im finding that when im just "chugging around" and try changing forcefully it jars my wrist every time as it seems to jump before it engages. How long did it take you to get it into 3rd 1st time everytime?? I keep seeming to either get 1st or 5th lol.
Cheers
Talk soon
Something else to watch out for is oil being pumped out the breather. I run straight cut ppg with redline light weight shock proof oil and i have problems with the oil coming out the breather. Does anyone else have the same problem with there box? I added a longer hose and run it up into the engine bay to the highest point not the best solution but it has stoped losing oil. I think i might have to pull the box down and install a shield where the breather pipe is.
with the breathing thing I know john runs on both diff and gearbox basically an expansion tank. so he runs the breather up to a small tank which is ventilated. the GB oil can be thrown up into this little tank, then drain back into the box. basically just like the radiator expansion tank. seems like a good, simple idea. could be worth a go.
33 racer which oil do you use? If the breather problem can be solved down in the gearbox instead of further up in the pipe we can have a breather that will do what it designed for... What i thinks happening in my box is the light weight shock proof is very sticky and the gears are flicking it up onto the roof of the gearbox then with slight pressure the box create it pushes it up the pipe. Now im not sure if we have enough room above the gears to install something like a baffle to deflet some of the oil away from the breather. Does anyone have a box thats in pieces at the moment to check out if this is possible?
were using the shock proof light i think it is, the blue one which ppg recommended for the box.
We dont have a box in pieces unfortunately, however i reckon the mini catch can with drain back would work well for it.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
