Hey guys had my r34 broken into today, tried to nick my system but alarm and i scared them off thankfully..
bad news is i lost my passenger side window because they didnt seem to realise I had a window there and must have put a fist straight through it..
To my sadness there was no blood, wouldnt be to phased if there was tho .. reds faster anyways... would of been gr8 if he hurt himself tho..
Anyways to my point anyone know where to source a 1998 R34 GTT passenger side window?? O'brien didnt even know a 98 GTT existed and wreckers are yet to ring back so thought id hit you guys up..
If anyone can help please do.
Edited by DECIM8
https://www.sau.com.au/forums/topic/185495-car-broken-into/
I feel for you man; those windows are a pain in the ass to get a hold of. I had the same thing happen to me (do a search of my threads); except in my instance there was blood :)
My advice (from experience) - is to first see if anyone is wrecking a R34 and take the entire door assembly; else get it from wreckers. Nissan want HEAPS for that piece of glass so don't go there unless it's your last resort.
The reason why I said to take the whole door assembly is because it's quite an involved process to get the glass out; best leave it to the person doing the R&R job.
PS; have fun getting all the glass out from inside the door; took me a few days and I still found small fragments everywhere :D
https://www.sau.com.au/forums/topic/185495-car-broken-into/#findComment-3356254
Sorry to hear, its starting to be a common occurance seeing these threads scattered through SAU ... but as above, curious as to what area???
I heard noises around the cars at our house in the wee hours of this morning..... didn't sleep much after that!
https://www.sau.com.au/forums/topic/185495-car-broken-into/#findComment-3356353
My alarm went off on monday, sent me a message, i was like, alright fellas, its on...
pants were near door so i put them on, went out to the car, car looked fine...
Turns out, some sort of weapon of a car set the motion sensor off... cause it did a lap later... sounded like an F1 car... I was inside, but awake this time to hear it... Set the motion sensor off again... Must have been going f**king fast too... well over 200k... Only heard the sound for about 3 seconds, then it was gone... it rattled the windows of the house too...
https://www.sau.com.au/forums/topic/185495-car-broken-into/#findComment-3357032
You know how hard u have to bash the window to smash that glass its about 4-5mm thick .. its not going bang without a fight ..
Hence my alarm blaring away.. intentionally loud for effect of GET THE f**k OUT OF MY CAR YOU PRICK!!!
Never seen a silver R34 in campsie .. have seen a yellow one .. looks alot like the powerplay one.. actually identical
https://www.sau.com.au/forums/topic/185495-car-broken-into/#findComment-3358103
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
