DrMoShen - I have an AXIS that has had the factory stereo removed.
The entire plastic dash surround has been replaced with a new one that takes a double DIN unit. It doesn't quite colour match, but you wouldn't notice at first.
I've got an Eclipse CD5030 head unit installed that works really well.
The radio is hooked up to the factory antenna and the reception is good. You just need an adapter to combine the two antennas.
Cheers.
What swayed you towards the Eclipse over other units?
It was recommended by the installer (http://www.fhrxstudios.com.au/)
It talks well to 3G iPhones, and has a very adjustable EQ.
Did you just put in the head unit or did you do speakers, amp, sub etc as well?
so have you found one you want to buy yet?
I know what I want. I've just got to wait until one comes up.
I'm probably going to be stuck with the car (for better or worse) for 10 years so I've got to make sure I'm happy with it.
OK so we all now have a stock item we can buy off the shelf here in Australia rather than going the whole Japan or US route.
A couple of months ago Danny(for those that know him) approached HDI to get them to develop an intercooler kit to suit the M35 in Australia. Those kits are now available from HDI as a bolt on production run item. Please note that like all business's if they don't get the sales they will drop it from there line up.
The kit uses the latest technology in IC's being the GT2 core. It's made a huge difference from the bottom end through the midrange to the top end in my car. It also has an awesome displacement of heat even in 40 degree weather.
Kit pricing as follows but will need to be confirmed with Jason at HDI:
*Full kit with IC, all piping, clamps and fan - $899
*IC only - $450
*There is a cheaper option but you will have to talk to HDI directly.
http://www.hybrid-power.com/index.php
P.S. More photo's are available just PM me though.
Edited by Jetwreck
*IC only - $450
Did they say how much to install. .
it's not a big job...give em a ring....I would say about $300 though as it takes about 2hr's. If they wont I will do it for you Jules.....for a small cost :down:
it's not a big job...give em a ring....I would say about $300 though as it takes about 2hr's. If they wont I will do it for you Jules.....for a small cost :)
Cheers. .will keep you in mind. . . my issue is that I lack tools. . well suitable tools. .
I think for the extra cost ($200 extra) that I will go with a Blitz FMIC kit through Just Jap even if its just for piece of mind.
Blitz FMIC
Some more pics from rhdjapan.com where they have an awesome amount of parts for the M35 :thumbsup:
I would say the GT2 core with its extruded fins would sh*t all over the blitz folded fin core for flow and cooling. I suggest you research the pro's and cons of each before the purchace.
Oh, didn't realise there was much difference. I am new to turbo tuning so please excuse me :P
+1.
I did a bit of digging into this one as I am looking for a FMIC upgrade.
Can't comment on the temp drop that each cooler performs, but regarding pressure drop (efficiency of the core - less is better)
Blitz CS - roughly 1psi pressure loss at 20psi
HDi - 0.2psi pressure loss at 20psi (claimed)
Hey Folks (1st Post)
Just like to say a big thanks in advance for all the helpful information in here.
My partner and I are looking into buying an M35 Stagea (hopefully either and Axis or AR-X) and reading through this has cleared some questions up automatically.
I can't wait to get down to Sydney and have a look at some up close and in person and test drive one.
I'm sure you'll be hearing from me more often hahah..
Chris.
  • 3 weeks later...
I'm looking at buying a 2002-2003 ARX turbo but was wondering what people are paying for insurance now. I'm finding it difficult to get a quote as it's a "dodgy import" (same old story I had back in 2001 with my u13 bluebird attesa). Oh, I'm in WA, 38 (old git) etc etc so should be able to get reasonable rates....
Love the car but I don't feel like paying $1100 a year for insurance especially when something like a turbo territory is $615!
Cheers
Edited by andynogo
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?   Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
    • Car has been sold and I am now selling leftover parts. Prices are non-negotiable as I will sell to my mechanic if it won't sell here. Prices are firm except for the Random Parts listed at the very bottom. All parts are genuine except for the S-Tune front bumper. Volk Racing TE37SL 19×10.5″ +12 5×114.3 pressed graphite with P-Zero 275 30 19 tyres [USED] $4,500 Wheels are in perfect condition, have been sitting in my garage for the past 6 years. Tyres still have 90% tread, but since they're now old, I would not recommend you drive hard on them. K-Sport Super Sport External Reservoir Coilovers (made to order) [NEW] $2,500 Front spring rate 14kg, Rear spring rate 7.5kg Fork Type. You can read all about it here (https://www.k-sportracing.com/product_detail.php?Key=12). I was going to start tracking the GTR, but never got around to it. Paid $3500 (after USD conversion and taxes). HKS Kansai Service Tower Bar [NEW] $500 Never fitted in the original Japanese box. R34 GTR S-Tune Fibreglass Bumper [NEW] $500 No mesh - No Box - No damage - just dusty. Nitto RB26 Clear Timing Cover [NEW] $50 Couldn't fit RB2630 due to bonnet clearance. HKS Piping Kit Special Type (BNR34) & Apexi Power Intake Air Filter Kit & Password JDM Adapter [USED] $1,000 Missing some rubber hoses and supports, but you get what you see. Nismo NE-1 Weldina Turbo Back Exhaust & Custom 3.5"straight pipe [USED] $1,000 Needs some love, but perfect for those who want to go back to OEM+. Bayside Blue Aluminium Vspec Bonnet/Hood [USED] $700 Came off my GTR. Unfortunately, the tips have been slightly ground down. It will need some repairing. Bride Low Max Super Seat Rails [USED] $350 The price is for both sides. Will post pictures when I get a chance. Random Parts [USED] - negotiable Standard rb26 cams (intake and exhaust) $10 Stock amber front indicators $10 Standard GTR bumper lower side grills $10 Stock amber side indicators $10 Nismo Sports Resetting ECU $50 Water reservoir $10 Stock airbox mouth $10 Stock fuel rail $10 Stock coilovers from R34 GTR Vspec $100 PM me which items you are interested in. I do work 9-5, so I will be responding daily at best. Best time for pick up is after 5 and before 7 on weekdays, or i can work something out on weekends. I will only accept cash or PayID. Pick up only - located Epping NSW area.
