I came accross the Stillen Cold air for the G35.
http://www.intensepo...hicoairbox.html
do you think it would fit in our M35's? comparing between this and my sisters V35. the box is the same.. would the AFM tell it to f**k off in other words.. lol
Yes, It does fit.. Danny had it fitted to his Gold ARX when he had it.
http://www.intensepower.com/sthicoairbox.html
Yep, as Andy said, straight bolt in... but sadly it is canary material in Vic (you already have the FMIC)
yeh but it looks stock...and its sooooo nice.. :( thanks for ruining me cam haha
Would they notice it though? coz it looks stock right?
You see the pod through the powerduct
I've seen the setup...it is nice....sounds good too.....why is it defect material.....the POD is separated from the engine bay?
irrelevant. One intake mod allowed in Vic.
Aaron has a FMIC so that is it for legality.
yeh but.. :(
but the standard is FMIC. which means its just a replacement right :ph34r:
It could, why dont you buy one and see mate? :)
  • Like 1
lol ok me and scott decided. this is happening after my first tune. so the addition of it being added can actually be determined as worth it or not.
if its an 11 hp gain for vq35de then it should be huge for a forced induction - with the addition of a larger suction pipe.. plus i'll find a loop hole before then.
Looking at Stillen's site:
http://www.stillen.com/product.asp?id=STIZTBE01&c=PE&year=2003&make=INFINITI&model=G35%204DR
What's the 2nd kit? a straight tube?
Interesting that no one's got a CAI on the M35 yet...which means the stock air box is...tolerable?
2nd kit is for N/A VQ35/25's.
You can get a pod and enclose it if you really want one. Blitz and M's have pod "kits" but they just sit behind the headlight.
Stock airbox with powerduct/home made powerduct will be sufficient.
the Z tube is a piece that goes between the AFM and the throttle body. The std G35/V35 PNM35 unit has all these baffles and shit that is designed to reduce intake resonance. This gets shafted in place for a straight tube off a Z33. more power(?) and better intake sound.
Wont fit on a NM35
Edited by PN-Mad
Hi,
I have been lurking here for a while now......
I have been wanting to get a Stagea for about 7 or 8 years and I am finally about to make the move.
I am looking at M35's but after hours on this thread and others I am a bit concerned about the turbo issue.
Are they guaranteed to go about 100,000km, or is it just a few that it happens to? And would an ARX4 be worse due to the higher boost?
As far as I can tell this is this case and the repair bill can be around $2k.
If anyone could clarify it would me much appreciated.
Cheers
Hi,
Cheers
NO guarantees on the turbo's at all, I have been told of them failing as low as 50'000km (but that car was found to have at least 50'000km would back on the clock) and I know mine was still good at 125'000km (ARX). Whilst it was still working, it was starting to go as oil was leaking from the bearing. I think if you look after the car, change oil every 7000km as a minimum with quality oil you could see 150'000km from this turbo. You are going to have to hope the previous owner looked after the car as well as you would.
If you need to change the turbo, there are a number of option to rebuild the turbo. You can have it rebuilt the same size from about $800 or a large high flow up to $2000. The removal of the turbo and replacement is the hard work. The best method is to remove the motor and gear box. This is about 6 hours of work so a few dollars there.
If the turbo worries you, have a look at the PM35, the NA version of the same car with a 3.5L motor. Very good car, newer and a little more expensive. They are available from North Shore Prestige.
Good luck with your decision.
Cheers
Andy
  • Like 1
i own an m35 with 117k on the clock - probably more as the cluster HAD been removed at some stage before - and its still going
also have another one with 105k on the clock and its also running fine.
if you look after it, it will keep going.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
