Hi,
I have been lurking here for a while now......
I have been wanting to get a Stagea for about 7 or 8 years and I am finally about to make the move.
I am looking at M35's but after hours on this thread and others I am a bit concerned about the turbo issue.
Are they guaranteed to go about 100,000km, or is it just a few that it happens to? And would an ARX4 be worse due to the higher boost?
As far as I can tell this is this case and the repair bill can be around $2k.
If anyone could clarify it would me much appreciated.
Cheers
Mine now has 138000 on the clock and the standard turbo is working fine. I guess the issue is that you dont know how the car was treated in japan or if it was modified but then returned to stock before shipping over here.
It is a bit of an unknown but as mentioned if you budget enough for a replacement then what's the worry? Adding a couple grand extra is still cheaper than a PM35 and once replaced the turbo should never need replacing again.
Further, if you do spend nearer the $2k mark to replace the turbo, you will come out of it with a much better turbo than stock so its not all bad news :)
not a bad way of looking at it :)
Hi,
Cheers
My turbo (NM35 ARX) was found to have chipped exhaust turbine and scoring inside the housing at 65,000km. Was still going fine and sounded normal - found while replacing dump pipe.
Kms on it seem genuine based on other wear and tear and was unmodded except joke mods like nismo badges, radiator cap and pedals.
Think there are many variables as mentioned by others that effect life expectancy including fake kms. Torque convertor failed at 65,000km under warranty which was interesting as it put the motor into a sort of limp mode.
So definitely buy through an import yard and get good extended warranty if you can.
Cheers for the answers guys. Some good points about the turbo.
Warranty probably wont be an option as I am currently looking at a private sale vehicle.
However I am getting my mechanic to do a thorough check over it so hopefully that will give me an idea of the general condition.
Not sure if you can determine the condition of the turbo without taking it out and inspecting it...even a dying turbo could sound normal
  • 3 weeks later...
Turbo may be on it's way out (will sound odd - but they are quite loud from factory)
Transmission should be very smooth. There will be a little lag when changing gears which is normal. Check that the tiptronic works properly.
the trans should NOT grind at all, if it does it may have been serviced with incorrect fluid.
Rear Anchor Points can leak if not done properly during compliance (water damage is bad, mmmkay?)
There may be an oil leak from the passenger side rocker cover, check for oil stains on the heatshielding and the turbo (both directly below).
If there is, get the yard to change the rocker cover gasket (~$20 part from Nissan, but the intake manifold needs to come off)
i thought you have to change the whole rocker cover for us?
No, you are thinking of the oil leak into the rear passenger spark plug. If you have that, then yes you need to replace the whole rocker cover to stop it permanently.
I am talking about the common oil leak from the passenger rocker cover. There is a rubber seal that is easily purchased from Nissan that sits under the edges of the rocker cover (being rubber, it can become brittle and leak).
motors not out.. i have that sark plug leak issue, but its VERY minor..
dont think its worth fixing just yet. it doesnt even go through a/4 of a litre until i service the car next so ill wait till it becomes important i guess.
ohh dude thats a risk. seeing as you cant drive your car at the moment. now is the perfect time to do this
If you give me more work to do I will be cranky Iain. :domokun:
His leak is into the spark plug hole, other than silicone, what do you suggest? I don't think he can afford a new set of covers.
Hi Guys,
While checking out my engine (I got the car yesterday), I noticed that one of the hoses had been blanked off.
On the picture below from another car, it is the one with the red end.
Where should it be connected to ? Why would it have been disconnected ?
Thanks, Steve
Hi Guys,
Thanks, Steve
Hi, whitestag.
The hose with the red cable tie at the front of the plenum leads to the boost sensor for the dash display of Stageas with the single DIN 3 gauge pod above a single DIN stereo.
Being that yours is an AXIS, & I assume it has the Bose audio package; it doesn't have the gauge cluster, & therefore doesn't need the boost sensor. This sensor only supplies the dash gauge; not the ECU.
You could always use this barb to supply a dash mounted boost gauge if you wish to fit one.
Hope this helps.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
