250T RS Four = VQ25DET with ATTESSA.
250 RS Four = VQ25DD with ATTESSA
T = turbo
Four = ATTESSA AWD
Not sure. Everyone's been hi flowing them....starts from $900 (hypergear)
Stock vs Stock, the WRX would be superior in every aspect I'd say. Mods vs Mods I'd think the WRX still has the edge due to its weight advantage...
Not sure - but you can tell the cars age by checking everything else (interior, exterior, wear and tear etc)
GPS cannot be used here...to use the VDU you'll need (well, yuo don't HAVE to) get a translation done. Andy & Ducati are the people to speak with...
Don't see why not. Andy's in Sydney, so's Northshore...
Thanks Buddy, that's given me a much better idea.
WRX is smaller though isn't it? So wouldn't be superior in every aspect. Also every WRX wagon I've been in feels cheap inside compared to the M35. M35 feels more solid, and expensive. Just a nice place to be.
My original post was in relation to performance, not functionality or quality. I can tell from the pictures that the Stagea cremes the WRX for quality of fitout.
The Stagea looks large and cumbersome. I've driven my old mans Ford Territory and that feels cumbersome.
Would people describe the Stagea as a Gran Tourer, more than sporty OR is the suspension stiff enough that body roll isn't an issue when pushing it around bends.
Edited by Drogba
Hey he wasn't asking about the interior ;p
lol, stock RS with exhaust (no dump) vs stock WRX with exhaust.
WRX wins from standstill, but rolling start RS should eat a GD WRX (speaks from experience)
Hmm maybe Ur right. I just think with our gimped throttle and weight that a Rex would be superior...
You are talking about a stock family wagon, of course it wont have race suspension under it but there are plenty of options if you want a firmer ride. Stock they are just a wagon.
Most of us look to upgrade to coilovers and stiffer sway bars. The brakes can be upgraded very easily, the power/torque can nearly be tripled without opening the engine and with just a highflow turbo. They can be as sporty as you want them to be, certainly not Territory cumbersome but not light either as they weigh around 1800kg.
Operative word there is "Family." That's been the problem with the lack of information on the net. I couldn't even figure out what market it was aimed at. So, stock it's nothing too dynamic but some minor mods and you can have the best of both worlds.
Upgraded coilovers, swaybars and turbo, how much am I looking at here for that. If it costs too much it could be cheaper just to buy a WRX wagon.
I think these sort of cars are the way of the future. Luxury and performance without looking like you've got a small wang. If had infinite money i'd go the new Ferrari FF or the Audi RS6 Wagon.
The natural balance of the Stagea M35 is the best on the market for the wagon with weight distribution 52% front axle and 48% rear axle. This is a great start for handling but it can be easily improved with the fitment of sway bars alone.
I can do the language conversion on a series 1 M35 at NorthShore easly as my work is not far away.
Cheers
Andy
Put it this way, I have surpassed the performance of the RS6 Wagon, great handling and nice modern interior for a quarter of the cost of the Audi. (That's my pick if I had the cash.) No plod have ever shown interest in it either, just the way I like it.
Cheers
Andy
Thanks Andy,
What price region am i looking at to get this done?
You've surpassed the performance of a car holding a lambo Twin Turbo V10! Be Jebus
I should be able to crack 11's fairly easily once the new turbo goes in, if it all holds up. What do the Audi's do out of the box?
Looks like we have nailed that car.....what's next!........you just got to work on cracking that 171.5km/h Scott :P....lol. Without the limiter(which I don't have) and with these ratio's I am pretty sure these cars would be good for about 250km/h......but an RS6 is made to cruise on 250km/h....but how often do you do those speeds.
I have to say that the last time I drove a WRX I was completely unimpressed!
20K(car) + 10K-12K(mods) and it should match an RS6........then you can have a couple of toy's in the Garage as well with the change.
Edited by Jetwreck
It will run off the stock ecu to a point, but it will run like ass and possibly hit airflow cut as the ecu isnt tuned for the extra airflow. My suggestion is not to go too large and if you don't plan to run the emanage eventually, keep the wheels almost stock sized. (or just replace the turbo with a stock one)
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
