It get's blocked up.
I've been lead to believe that if you clean it out, use good oil and service it regularly you should be fine.
To be safe, if you're running a standard turbo you can drill it out to 2mm, and if you're running a highflow you drill it to 3mm.
Scotty and Aaron are the experts, but that's what I've been lead to believe.
Any peeps on here interested in a wood trim interior for an M35? I only ask as I'm going to paint it all black unless someone wants to trade...
You can vinyl wrap the timber part of your dash and it looks pretty good.
I would just drill it out to 1.5 mm if you plan to keep the stock turbo, 2.5 mm if hou go for a bushed core.
The banjo threads into the block just in front of the passenger front drive shaft.
Great info, thanks guys. Might drill it out when I go to see my old man in a few weeks since he has a drill press. I don't even have a vice at the moment!
I don't suppose some one on here knows if the centre console on an M35 is interchangeable with the V unit? Chasing both the radio surround and lower gear stick surround. Figured if they are interchangeable it would make finding these parts a million times easier. :)
yes, they are both inter changable.
I saw one for sale on the V series forum
Well I've set mine to 360mm front and rear, this gives about 15mm gap between tyre and guard with my 245/45-18 tyres. I might drop it another 5mm but probably not worth the trouble. I like to leave 10mm gap so it doesn't get too many looks. With the aero front bar it just clears those cement stops in car parks. Its funny, when I look on the RAWS site and look up my car it shows the stock height (i think its listed wrong) and minimum height. It states unladen F and R 365mm and Minimum F and R 346mm. I had it at 345mm at one stage and its bloody low so I think the figures are wrong.
Edited by slippylotion
Rear under spoiler for the left and right muffler system
I haven't seen any mention of this here before therefore I am just shariing in case someone want to take this path...
http://global.rakuten.com/en/store/zeesis/item/m35-supoir/
Cheers
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
