Does anyone know if there is a replacement offset bush kit to correct camber fir the front upper control arms?
I Need to correct the front passenger arm as it now has 2deg neg camber from lowering it compared to the drivers side having 1.2deg neg.
that doesn't sound right but......is this what you are looking for though.
http://www.superpro.com.au/superpro-parts?id=SPF3297K
there is also the strut to chassis arm bush's that fix pull to the left.....these are one of the exchange sets I am offering...http://www.superpro.com.au/superpro-parts?id=SPF2848K
What is involved with putting the M35 into RWD mode?
Can you simply pull a fuse or does a wire need to be cut? Once the new wheels go on, in theory the space saver will be the wrong size for the Atessa system, so I figure I could pull the fuse and shouldn't have any problems.. correct?
incorrect. pull the front shaft out
Hard job?
The space saver would be trouble with the different wheels, wouldn't it? Think it would be alright to limp it to the next major town (could be 200km?) on a long drive to get the tyre fixed/replaced?
I would just drill it out to 1.5 mm if you plan to keep the stock turbo, 2.5 mm if hou go for a bushed core.
The banjo threads into the block just in front of the passenger front drive shaft.
Just following up on this, does anyone have suggestions for a banjo bolt that is already the right size? I don't have a drill press and it could be a while until I get to one. Seems like a sketchy thing to do without one (I don't even have a vice at the moment!)..
For the guys looking for more suspension adjustment on there M35:
http://infinitihelp.com/diy/gcoupe/projects/infiniti_g35_rear_camber_kit_installation.htm
I came across this vid of installation of rear arms in a G35, the only bit I found a little disturbing was when they decided to slot the rear arm hole in the cradle and use an offset washer... thoughts?
I believe there is an off set bush available but i have never seen anything like this...
http://infinitihelp....nstallation.htm
Considering the rear arm already uses an eccentric bolt set up; I don't really see the issue.
This method of adjustment is commonplace; many cars use it without issue, and the slotting that they do in this instance is to add MORE adjustment to the existing range available.thumbsup.gif
Does it really, I didn't know that... WOW that came of a little sarcastic.
The outside bolt is not correct? I only ask this as when i dropped the rear arm in mine I took out the bolt that attaches it to the hub on the outside is just a normal bolt, did not touch the inner one. Has the stock inner bold have much adjustment?
Mike.
Mike, this was the reason for my reply. Naturally, I assumed you hadn't looked at the subframe & seen the factory adjustment is exactly that. No sarcasm.thumbsup.gif
Mike.
No, the bolt in the hub is not eccentric, and it's actually bushed in the hub too. The back arm is a toe adjustment arm. For anything up to around 2" lowered the OEM eccentric will likely suffice.
Depending on how low you drop the car; the toe can end up being so far out that you cannot use the OEM eccentric bolt to adjust. This is normally at stupid "fitment' and "stance" brah ride heights.rolleyes.gif
For normal people; a more "eccentric" (more adjustment) eccentric will do. This is why they slot the hole in the subfame out a little more.
If that's not enough; you can move to the length adjustable arm; as per the dolts in that video who seem intent on using a power driver to undo every bolt, regardless of whether it saves any time, or is actually any easier.
With length adjustable arms; I have no idea why these guys feel the need to ALSO fit eccentric bolts; if it were me, I'd set the eccentric in the centre of its range, and finetune the arm length on a wheel aligner. Then you can make small + or - adjustments with the eccentric.
But hey; I don't use a power driver on pre loosened bolts either...cheers.gif
Edited by Daleo
Thanks bud, going to drop the stag in for a wheel alignment now... I wasn't going to as I didn't think there would be any adjustment in the back and if they couldn't adjust anything then I didn't want to waste any $$ for no reason.
Mike.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
