It is BC coilovers but from a V35 - My sister is selling her v35 and I am buying her Coilovers - so please confirm why will not fit or wil it fit since they are BC brs
Fronts definitely will not fit.
V35 is RWD so the fronts have forks, M35 is AWD and do not have the fork.
Iron Chef can't do PM35's.
Northshore is the one to call... although they have also offered to do compliance for J-Spec and possibly Prestige.
How does that work? Seems surprising that one importer can use a compliance shop but not another.
Edited by jasevr4
Northshore are an importer, not just a compliance shop. And AFAIK they paid a tonne of cash to be able to comply PM35s, so they're pretty much keeping it to themselves.
But Iron Chef would know whats going on in the industry.
Seeing Jase didn't bother to correct my response via Twitter :P, I was referring to manual PM35s, which, to the best of my knowledge, no-one in Australia has.
I'm sure if I were to buy an auto PM35, the guys at Northshore Prestige would be able to comply it for my customers, same as they can for any of the other brokers.
Yeah that's what I thought. It's all good, just think there's some confusion going on here. Convince Matt to get one and drift the shit out of it.
I thought that's why they HAD to only use the N/A models in the latter years? Didn't they change the emissions laws around 2004?
Still, if I was him I'd be buying a VQ30DD and doing an engine swap between the two cars and then trying to get that one converted. Otherwise he never got import approval and just chucked it on a boat assuming he could?
Edited by jasevr4
+1. As I understand it, emission laws changed between 2003/2004, thus 03 NM35s pass, 04's fail. Some other poor bloke when through all that hassle.
Not sure if you can do this, but what the hell. I'll suggest it anyway. :whistling:
I reckon the cheapest and quickest way to get it registered again would be to:
1. Consult with automotive engineer regarding getting the car fitted with emissions compliant motor.
2. Buy it
3. Fit 350Z VQ35DE and all emissions gear in place
4. Get Engineered with the alternate engine with all emissions in place and get car complied.
Compliance is the biggest load of $hit for M35's. They practically do nothing, although they did do the emissions and crash testing with a dummy to start off with, and that is what you are paying for.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
