Generally means one bulb is out, or technically, there is not enough resistance in the system.
Checked all the bulb, and/or installed LED lights anywhere?
Thats about it from my experience.
Ok so the full story is that it was dying a slow death. I'd indicate and three click in I'd get two fast ones, then three good ones again. I figured that was the sign for "replace the globe", since it was on the rear left that wasn't working. So I did, but it didn't change anything, and now a few days later, it just clicks fast all the time and I have no indicators on the left hand side.
Sorry, read this and I didn't post.
Have you got the indicators in your mirrors?
I had similar behaviour from mine when I picked it up from the alarm installer, ended up they'd knocked the wiring for the mirrors, and because they're scotch locked into the main harness the scotch lock had cut through the wiring.
Wiring is down in the drivers footwell, behind the panel forward of the door.
Not sure if that's what it is, but worth checking. It was flashing fast all the time and I had no indicators in the left hand side, but the LEDs in the mirrors did.
I'm not finding much. >_<
Mine doesn't have the mirror indicators so I may be barking up the wrong tree.
Actually, thinking in the same mindset of Ryan's situation (cable slowly being "pulled" or broken, which makes sense in my situation), is there a cable from the ECU that would stop the indicators working for just one side of the car? I did do the wire snip mod on the same day as the indicators started becoming intermittent.
Ah ha!
Found this document (not sure if it's really that relevant), but it at least pointed me in the right direction..
http://www.psedog.com/cars/fsm/g35/coupe/2003/bcs.pdf
Went searching and found that there's a pink and.. yellow? cable down there that had some electrical tape around it. Seemed a bit suss, so I took the tape off and sure enough the solder had come undone. I suspect that when my alarm was installed the installer cut this wire by accident and soldered it up but while I've been under there it's come loose. Anyway it's all fixed up and working now so I'm stoked! :thumbsup:
Ah ha!
Awesome, good work!
Hmmm turns out I didn't fix the problem.
If the BCM was stuffed, would it permanently not work? Or be intermittent? Intermittent seems like a cable contact issue don't you think?
Are the BCM's easy to swap in and out? Is it just a matter of unplugging it, putting the new one in and plugging that in? If I can borrow another one just to test it would certainly make troubleshooting a lot easier.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
