What temps have people had their M35s up to?
Little worried last night's overheating might have caused problems. It seems fine, and I understand M35s run warmer anyway, just like to put my mind at ease.
I have seen 125 degrees with an airlock in the system, and 116 on the straight at PI. Hopefully no bubbles in your radiator or overflowing coolant reservoir and you should be fine. That said, I am rebuilding another VQ25det atm due to a blown headgasket from overheating...
I finally got the 350 x 400 x 50mm trans cooler in tonight, that should take care of the gearbox temps. I still have to install the fan controller, there is a 9 inch Spal fan on the trans cooler and a 14 inch on the engine oil cooler. Both fans should turn on at a preset temp once I wire it up. Not much room left in front of the radiator now... :)
Pic?
Very reassuring guys, thanks. Sooner I can get the Mishi in the better!
Funny thing about the coolant reservoir. Not sure I've ever seen the level change. Not sure if that is good or bad. Been the same level since I got the car 18 months or so ago.
Pic?
It was pitch black and beginning to rain, with lightning on the way. I was glad to have it finished before the storm hits. Shame there is no room for the hoist in the shed. :(
The trans had the thermostat inline and also ran through the radiator so there was no problem getting it up to temp quickly. I had issues keeping the temps under control though. The fluid comes straight out of the torque converter into the cooler lines, mine was seeing stupid temps as around 30kw is lost as heat in the converter at full noise, quite often enough to boil the coolant in the radiator.
I have removed the radiator fittings and thermostat from the lines so there will definitely be issues getting the temp up now. Hopefully it will still warm enough to drop into 5th fairly quickly, if not I will re-fit the thermostat.
It will definitely rise once you double the amount of coolant in the system. What pressure cap are you running?
The Nismo cap. 1.3... Bar?
Car has never been overheated though, and I've never done anything to the cooling system... Until the cooling mod.
It must have had a large airlock in the system, you need to recheck the coolant when cold for the next few mornings any time you dump it and refill.
I took 2 pics for you guys, the fittings on both coolers are touching the plastic undertray so run the full height of the radiator. Hopefully the Mishimoto will still do its job. This is all possible due to the intercooler being cut down and moved forward, bolted under the intrusion bar.
I also got around to fitting the fan controller for both thermos and for displaying trans/oil temps. Kewish have asked me to modify a few of the signals going back to the TCU, including both temp signals and the main line pressure solenoid. Should be interesting to see what I can do manually with regards to line pressure, and the best part is, no more limp mode if the fluid gets too hot at the track. :)
I need to paint the control panel stealth black yet, if I cbf...
No Navi in the base model... ftw... :)
I can now run full line pressure, (farkin hard shifts), or factory adjustable line pressure with variable adjustment using the TFT temp knobs. Seems to work well on around 60 degrees from my quick play today. It's off to Kewish next Wednesday for pressure readings, I think they will be impressed with the mods. :)
So can i get one thing straight , these air bag like fault/issue lights come on basically due to 'cheap' wiring of sorts ? Or were they connected incorrectly , like the example with the person saying that their battery was going flat and then the airbag light comes on ? :S
Edited by RB25SEB
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
