I'm Calling The Sau Prez Out!
Thats right, it's Physical Challenge time.... I know the SAU VIC Prez likes a Krispy Kreme dount on the odd occasion, so this should be no prob...
A one-pound beefburger fried, topped with cheese and bacon and sandwiched between two Krispy Kreme doughnuts.
A real heart stopper :)
https://www.sau.com.au/forums/topic/186150-im-calling-the-sau-prez-out/
  • Replies 58
Alright this sounds like something that needs to be attempted SMASHED!!!!!!!!!!!!!
Or was thought up while smashed hehehehe
LOL, call it the SUPER WangBurger.....to be consumed with a WangBuster
You have been challenged leewah, SAU honor is at stake
Umm Age, Are you f*cking mental? If you wanted to see a real recipe for disaster, that burger is it!! Cholesterol City, here we come!! Are you that desperate to win something that you have to stoop so low as to challenge me to something physical? And it's not just a physical challenge, it's a damn disaster of a challenge which could harm my internals which will no doubt require a rebuild.
I'll tell you what, I'll take the challenge if I can nominate a proxy to take the challenge on my behalf. SAU-Vic are a team after all :(
LOL, call it the WangBurger.....to be consumed with a WangBuster
There already is a WangBurger Rossco. If you got your a$$ to DECA, you'd know all about it ;)
jeez man......one bite of that and the poor guy will have cholestrol problems......
I'll tell you what, I'll take the challenge if I can nominate a proxy to take the challenge on my behalf. SAU-Vic are a team after all ;)
Ummm i did'nt think that far ahead about the logistic of the actual challenge... :P:D I thought of the SAU member who would be the most likey to survive eating this burger....your name floated to the top of my brain. :P
I think it should be done.... i'd like a crack at that burger, or failing that sell tickets to watch the Snowman eat one! :yes:
Ok, after brief disscussions last night, this burger is not that hard to assemble. All we need is a Macca's next to or near a Krispy Kreme.
2 donuts and 2 double quarter pounder burger's with bacon and then it's alive............. :mellow:
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
