So brake experts.. need some input...
I run Stock R33 GTR Brembo calipers... DBA5000 discs, braided lines, Removed stone shields, Master cyl stopper... with RBF600 fluid and DS2500 for street and DS3000 for track.
Everyday driving/street on the DS2500 the pedal is reasonably hard, good feel, and gives me confidence.
For track days i change pads from the DS2500 to DS3000, as soon as i get back in the car after changing pads, the pedal feels softer... a bit spongy... Now since the only thing i'm changing is the pads, You'd have to assume its the pads, or the pads not bedding to the discs properly... At the track the pedal is soft as well... so coming up to a corner i'm on the brakes much earlier than i should be at about half pressure, if i jump on them to hard the pedal just about hits the floor and i have to take a 2nd stab at it....
It's not pad knock off because i tap the brakes with my left foot before jumping on them for big stops....and even when i take a 2nd stab at them the pedal is never hard.
Now the weird thing is i found i had a hard pedal at one particular corner at Phillip island.... Turn 5.... not sure why... not a high speed stop really....
Now after the track day i put my Street pads back in DS2500 and the pedal seems to be hard again.... coincidence?
Options i have: Rebuild the calipers? Replace/reco the master cyl? Replace the Brake booster?
First thing i'm thinking of doing is putting a brand new set of pads in (i have a new set of DS3000 sitting in the box at home).... and see if the pedal is hard with those in....
Any input/suggestions welcome...
https://www.sau.com.au/forums/topic/186408-spongy-brake-pedal/
No i don't bleed the brakes after i change the pads.
I bled the brakes about a month ago with new RBF600 fluid....
When i change the pads i just push the piston back into the caliper to fit the pads in... I don't crack the bleed nipple.
I hope you have the lid off the master cylinder when you are pushing the pistons back in with the nipples closed. because the system is sealed and if you are pushing a piston back in that pressure has to go somewhere and often it ends up getting forced past a seal somewhere (master maybe) which can stuff the seals.
90% of the time spongy pedal is solved by bleeding the brakes. especially if your set of 3000s is more worn than your 2500s is possibly a reason why you are getting poor pedal.
While I'm no expert....I'd try the new pads to see if there is a difference first.....if not try a proper bleed and then try the seal replacement kit.
I'm not sure why two sets of pads would have such a drastic effect on the brake pedal feel....would a big thickness difference matter?
I personally think you are just making excuses for not being able to run a 49. :(
haha yes lack of balls or lack of brakes? Probably about equal, i recon there is about 2 seconds to make up for my brake issues and another couple of seconds to make up for lack of balls..... Hopefully the brake issues i can fix easier than the ball issues :P
This link is interesting - http://www.zeckhausen.com/avoiding_brake_judder.htm
Talks about changing from street to track pads... not really related to a spongy pedal tho... but i do get brake judder as well sometimes...
At Sandown before Dutton when Juz was gettign used to the car she was gettign brake shudder pretty bad...a bit of housekeeping and change to the way the car is driven and next session they were good to go... :domokun:
I think the real big hint to the problem is that in a bleep between corners when you have had big revs on board in teh same gear and you are braking from big rpm without a down change...see if anyone else thinks the brakes working well in this instance hints at the problem ????
Yeah i'm not sure if that was co-incidence or what, maybe it wasn't every time i went to that corner, but i just seemed to notice a hardish pedal at that corner, where as not really anywhere else....
I dunno, stupid brakes!
Well....could be related to vacuum booster leaking or not working properly, and you only notice when you are pushing them hard.
vacuum boost (obviously) needs vacuum to work, you only get vacuum with a closed throttle.
do you left foot brake (ie throttle still open when on the brakes?) if so you may not have any vacuum in the boost and backup cannister so you get no assistance at turn 5. I have this problem at wakefield at the top of the hill - I keep throttle open through both right handers but never have any vacuum for the quick dab on the brakes before the second corner.
One simple thing to start with - make sure the 1 way valve on the way to the vacuum canister works (ie you can blow through it one way but not the other)
Yes i left foot brake to take up any pad knock-off and to make sure the brakes are still there before any big stops...
The one corner i seemed to notice a hard pedal was a good thing, when i say hard i mean hard and it seemed to stop well.. wasn't like it was a hard pedal and wouldn't stop.
I'm not sure where the one way valve is, but ill have a look - I don't have to remove it to check do I?
Valve is probably embedded in the hose - take the whole hose off to test.
Have you tried running the "street" pads, just to confirm it really is the pads, and not the fact that you are "racing"?
Running the street pads at the track? No... but i have run the street pads at DECA... Don't think i had the same issue there but i didn't really take much notice... I can't run my street pads at the track they will overheat.
PS. you have a typo in your signature blind_elk :whistling: 'stoke week'
Yes, but will you also have a spongy pedal? There are 2 major differences - the pads and the driving style. You need to eliminate 1.
Alternatively use the "race" pads on the street - is the pedal still spongy?
PS. you have a typo in your signature blind_elk :) 'stoke week'
DOH! thanks Edited by blind_elk
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
