Hey Russ - what times are you aiming for at QLR on say the National Circuit?
It seems the times there are pretty much on par with say a lap time of Sandown - so us Vics have a comparison to look at (look at V8 Super cars they qualify in the 1.10's at both tracks and looking at the Dutton results it seems that cars were doing the same laps times that did both tracks eg Matt Cherry did 1.19's at both).
Because it would be interesting for us to know how your times compare to someone like Marcov (R32 GTR) , JFK (R33 GTR) and Benno (R33 GTR). I'm pretty sure Marcov's best time at Sandown with RE55's was a 1.14.9. and the other 2 are I think in the 15's.
  • Replies 705
Posted Images
hey guys
hope to be at the track friday a bit before luch for the afternoon.
snowy - hoping for somewhere in the 1:16 region on the national at QR. (MID 1.17'S last time out, so we shall see)
i would have loved to have got back to wakefield as that is the track we wanted to test at, hoping for high 1:02 at wakefield.
anyone had any experience with AO48's, as nearly all the cars are on them at Tsukuba, ( i have heard they are worth a second a lap)
i need comments??
cheers russ
i need comments??
worst semi-comp I have used Russ. They were uber crap. They were definitely 1-2s a lap slower than the bridgestones. I understood a lot of the cars run the A048's over there for these comps becasue they get sponsorship to run them...
I have heard the new DZ03's are the go but I haven't used them to be able to fully comment. Otherwise I still think from all the ones I have used that the RE55's are the best to date. (A048's, A032's. R888's, DJ01's, DZ02's, RE540's and RE55's)
thanks snowy - i thought they were suppose to be crap too!! (was wondering why they use them, but that makes sense) i am trying the dunlop O3G's at the moment and think we will stick with them.
A holinger is coming!! but it's for that r34, went for a drive in an r33 with a holinger and ignition cut of the gear stick, it was amazing, really linear power.
russ
definately not the yoko a032r they are our control tyres and are slow and horrible (go off quickly)
the dz03 or re55 would be my choice, considering everything else you are doing you should pick up a few sets of super softs and just change during the day.
HPI did a artice on the Saurus GTR, they have 2 engines for it, a drag engine, and a track engine. I can't remember what each one is though, i'll have to get it out to look.
Edited by sav man
Saurus GTR circuit engine and other stuff:
OS Giken RB30 engine 780ps at 7800rpm
6-throttle setup
T88-33D
OS Giken sequential gearbox
Grex Alcon 6 pot front 4 pot rear brakes
Carbon bonet, frp front guards
Aircon, ABS and Power steering removed.
Boot mounted radiator
Welded in rollcage, spotwelded chasis
HKS torque split controler
Hope that helps
Edited by bnr#@
thanks again guys!
duncan thats not a bad idea, i cant seem to get a hold of O3G softs but will continue to try (if i cant get them before we go , i will get re55 softs over there)
i have been told that the nismo festival is the sunday before the race!! so i will be there for that, hopefully get to see the 2008 gtr!!
Update
Engine was started tonight!! sounds great!
car goes to CNJ torrow to have new middle section exhaust made to match new tomei down pipes, then back tomorrow night to finish off, start fitting decals and things.
also have to try and get new rear turbo oil feed pipe as it has a crack a the top fitting and is leaking(should have that sussed tomorrow)
wednesday thursday dyno time (after run in)
cheers russ
Hey Richard
nah the dumps the were cracked were on there when we bought the car! so atleast three years old and look like chinese copies of hks dumps. they were pretty ordinary dump pipes and i'm glad to get rid of them!
russ
yep, the tomei dumps are the best I've ever seen which is why I have set for my car. and I went for the twin 70m HKS front pipes to go with them. very nice quality and the pipes are welded to the flanges on the inside which gives a much nicer finish and no overhang. The HKS dumps (and the copies) are too small imo. sure split is a good idea but in practice you end up with two tiny pipes than then merge again after only a few inches and go to a 60mm outlet. not good.
Giant,
Are you still using the AAC valve and the air regulator on your engine?? If not, what do you use instead of them. thanks.
and which of the 2860 turbos are you using? the -7 or -5?
Edited by dontfeelcold
Giant,
HI mate
The turbos are -5 , i think! GCG helped us out with these and put the black heat coating on them and changed the bearings to steel cages etc.
with other question is that the valves under the intake manifold? if so , all that has been removed, idles is low on cold start up but comes good in a few minutes.
cheers russ
Yes , we have changed from the n1's, will find out if thats a good thing soon enough.
we stayed 2.6ltr because we want to rev it, and feel this is a safer option in that area as piston speeds increase with lengthening the stroke. fine for drag and short work but not as nice on longer distance stuff, i was lucky enought to be able to speak to the tomei crank engineer for a little while about the cranks and set ups while i was in japan, which was very interesting.
cheers russ
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
