this is looking good for me. I will be in jakarta at the end of november so I'm trying to tee up a flight across to tokyo the week before nismo festival.
I will have to wear my australian flag undies.
  • Replies 705
Posted Images
sounds like a top trip
good luck to the GTR's, but i think the EVO's will be unbeatable again
well I know that circuit battle was on last week and I heard from a bloke who was there that he had Mark and Russ's GTR clocked in the mid 1:02s!!! now that is fairly bloody hauling. he wouldn't tell me what they ran in the actual circuit battle, but when they were doing some testing laps 1:02s were happening.
well done guys. things are looking pretty bloody promising now. :D
hey gents
yep can confirm! 4 lap test in the afternoon after the circuit battle mark put out a 1:02.5!! and it had been raining right upto about 1.00pm. so track was far from ideal. there is definately a low 1:02 or high 1:01 in the car setup currently, which we are just wrapped about. the car is unbeliveable at the moment!!
car got packed in the container today , it will be sealed tomorrow and bon voyage!! phew!!
fingers crossed all goes.
well
nice to see my source was on the money mate. :rofl: I think you guys will certainly be quick enough to put in a great showing for us little battlers down under.
can't wait to get over there!
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
