  • Replies 705
Posted Images
awsome Dunc, will be good to finally meet you! and race ya! :)
i will try and get the videos down to you so you can get them copied! ( i have been a slack arse) can you pm me your delivery address?
bored tonight so just posted two vids for fun , first one is 1000mtr airport run in the QLD dutton last year. , speed topped out somewhere around 275 /280 not sure wasnt really looking!
next one is way back Vic dutton 2005 , thought i would put it up for a laugh just me overcooking underbrakes! had a nice set of new front AP's i was trying out! hehe standard rears :)
the car has changed some much since then it's ridiculous!! was dam good fun though!
Edited by giant
The new event will be called Superlap
and will be run at Oran park
website coming in the next few weeks!
TWO CLASSES (should stop ,the what catorgorizes a street car argument)
CLUB & PRO
different sub catorgories in each class, which dont quote me, but i think are
4WD, 2WD & N/A
Hopefully it will be a top event! trophies and prizemoney!
More info to follow when website is up.
russ
CLUB & PRO
4WD, 2WD & N/A
russ
Cool, well im in :blink: (not that i have a chance of winning against cars like yours)
My fav track aswel, thats a bonus!
rock out! April will be perfect. I will have the grey car back on track by then and hopefully I should have gotten your 35 here by then too, so you can make us look silly with a near standard car!
and troy, I will give you the keys to my 32 mate. you're a top steerer and since my car has ABS we will both be spared the brown moments I hope. hehe.
I may even have a new car to pilot which will be pretty quick, but mums the word for now. :blink:
Also watching intensely... that will give me a few months to get the GTR up to pace.
Will a CAMs L2S licence be sufficient? Or even needed? I'm debating whether to renew mine.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
