  • Replies 164
I reckon I will be posting something there too.
Far out there is some mindless shyt on that thread. Such narrow-mindedness only gives them a bad name. It is just pathetic.
Thats why I prefer to read Holden stuff over on the www.LS1.com forum. At least they are a bit more open minded.
Actually, I don't think Commodores and Skylines *are* completely different. Half the reason why I like the Skyline is because it has its roots in a family sedan. I just think they've taken up the "sports car" upgrade much better than any other.
The only thing lacking on the Skyline when compared to a Commodore is interior space. Well, price of the car and spares is also in the Commodore's favour I guess :(
it all depends what you want to do.
i owned a vl commodore. long story engineblew up, 5 piston ring lands cracked, and shittered piston number 8.
commodores are good for going bush.(stock)
skylines aint.
skylines are good for going around corners (stock)
comodores aint (stock)
it all depends what you have done to your car.
generally i think skylines are better for MY NEEDS.
One of the reasons I bought a skyline is for the price i would have had to pay to get the brakes, interior (hugging seats) etc.. was a little far fetched.
Some days I think... Yer that monaro looks nice etc etc.. Then I think about the price and what sort of skyline I could get for the same price.. GTR Territority.. :D
Im a dead set Ford fan, the only reason i brought the R33 gtst is cause its a coupe, which gives a sporty and better image and its handling and cause it was a turbo. If it wasnt for my cars fuel effiency i would of got a EF or a EL XR8, which i think they are damn hot and not many are modified.. U just cant compare a damn frigen dunnydore to a skyline, both are different category cars. Skyline handles better for its shorter wheel base and has HICAS which i love it :D Like if u got a cave men and showed him a dunnydore and a skyline, im sure he will choose the skyline coz its just a sex on wheels.
P.S. Im glad Ford fans are not as stupid as Holden hooligans. Their was a little comparing on XR6T VS Skylines and Supras on fordforums.com & 8out of 10 people respected skylines & supras, and others said it was a rice burner or what ever, but no one said either car was shit..
The thing i hate about Holden hooligans is, they think dunnydores are the best car on road!
KDR33...
The BA XR8 is still the nicest looking XR8 I've seen. :D
There used to be a Dark Green EL/EF XR8 that i occasionally used to see down south. Had a nice wirring supercharger noise coming from the engine bay with a lumpy cam. A big bloke used to drive it.
Guest wilco
I'll tell you the one thing Commodores have on Skyline's, is the price of insurance :D
My GenIII SS with minor mods is $817 per year and still dropping each year. I have looked into a few R32 and R33 options (as well as GTO, Supra TT, S15 etc etc), and the purchase of the Commodore 3 years ago was very much based on insurance, and a concern over getting a dodgy import. At least with the new bogodore I have some warranty (which being a Commodore I have used way way to often, engine rebuild, diff, gear box, clutch, master and slave cylinders, front suspension twice, brakes, paint, door locks, door seals, steering rack, steering pump, fuel pump, various trim parts, idle pulley, electrics etc)
I was looking at replacing this car with a GTR recently but have unfortunately given into continued investment with some better half influence.
I would prefer a GTR over any commodore for sure, I had a brilliant drive with an R34 GTR V-Spec a while back and it is a sweet machine.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
