Some might probably remember this same car having a RB26/30 and a powerglide dummied up in it,
but after some calculations it was soon realised that this combination was going to cost tens of thousands
of dollars to complete the engine alone. So the engine & transmission were sold and the project put on hold.
Six months later i came across a low Km LS1 and Tremec 6 speed. For a laugh on a saturday arvo a friend and I thought
we would see if it would even look like fitting, the joke soon became a reality.
Factory Nissan engine mounts were used on the cross member, block to mount brackets were fabricated.
The sump did not need any modification. The factory power steer rack was removed and a VL manual rack was fitted to allow for starter motor clearance. VX Commodore 1&3/4" into 3" extractors were fitted with slight mods, just had to tuck them in a bit. PWR Radiator to suit R32 was purchased and custom shroud and fan fitted. Gearbox crossmember was fabricated
as well as custom tailshaft with masive F100 front Uni. Jim Berry supplied custom clutch and flywheel. Factory LS1 wiring harness will be fitted.
Custom fuel cell was modified to house two Bosch 040 intank pumps and plumbed up with speedflow fittings through a Russell
inline filter into turbosmart reg.
I plan on running the engine aspirated at first with just a cam and valve spring change. Should make 350kw at the wheels.
Hope to fit twin Disco potatoes later down the track.
https://www.sau.com.au/forums/topic/187852-r32-ls1-conversion/
  • Replies 812
It took about 4 hours to mount the engine and box, about the same to mount the rack. the headers took a couple of hours to modify, fuel system took about 8 hours. still have to wire it but that shouldnt take to long. could easily do it in a week if you didnt have to wait for parts to be made, eg clutch, tailshaft, radiator etc.
;) how long did it take from the initial fit to turning the key?
whats a proper V8? it makes you wonder why its been done heaps if Ls1s are shit. but u know what your talking about, ill pull it out tonight.
man it's been done heaps, ls1's are shithouse should of got a proper v8... afterall it's a holden.... but either way nice work....
Edited by BezerkR32
Nice work mate.
How did the weight of the LS1 and gearbox compare to the weight of the RB30, geabox, front diff and transfer case?
Twin Turb's FTW, should have fit them first. :thumbsup:
I'd say the new motor would be lighter than the old one but the gearbox from the Commodore is monstrous. This car never had a front diff or a transfer case btw. :D
yeh, the engine is lighter being full alloy and having plastic intake, the new headers are also alot lighter
than the cast ones. the flywheel will also be lighter as well as the clutch assy as we are going from the standard 12.5" truck setup to a 10.5" clutch, actually using a GTR pressure plate, but the Tremec is big, think of a R33 5 speed then add 20 kilos. Its all good though as the weight is in the middle of the car and the engine sits further back than the inline six also. The turbos are something i would like to do, but want to run the car aspirated first. turbos, manifolds, plumbing, pipework, intercooler would add about 80kilos to the front of the car and would cost about $5500, not just yet. hoping to make around 350rwkw aspirated and turn the engine to 7000rpm, should be fun in a car that ways 1000kg.
I'd say the new motor would be lighter than the old one but the gearbox from the Commodore is monstrous. This car never had a front diff or a transfer case btw. :laugh:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
