1st and last mate. no more, lost enough hair lol.
planning on ducting the front bar when i get her back. the tossers will think the radiator is a cooler anyway.
trust me, the cam is big enough, its the bigest hydraulic comp cams has ground for a small cube ls1. we were gambling that the fact the car is lighter than your average comodore that we will get away with it. plus the diff ratio and 6 speed should help. ill send her over if the missus makes me sell it.
Does look great, though looks wierd not having anything hanging out through the opening in the bar. May have to glass it back to teh radiator so you dont see light through there.
Tell me where to write a 10k checque for the conversion and i will post it off....only i know it woudl cost way more then 10k :D
All it needs to be truly toss worthy is a close ratio box and a big silly cam to make the thing nice and peaky and make good top end. LOL, i seem to like spending money making cars slower :)
  • Replies 812
what diff ratio you running mate? and what are the 6 speed ratios? I know the commodores have silly gears in the 3s so pretty much any skyline ratio from the 3.9:1s to the 4.4:1s will be a big difference and should work well.
im pretty sure its a 4.3:1. yeh the holden ratios were way to tall, you get get a commodore to boogie by putting in a set of 3.7s. as for the box ratios im not sure.
yeah 4.3 will be nice. the commodore ones are just stupid.
legs arent the issue, i couldnt shift into 6th under 105kmh in the commodore without labouring it.
i put it off the clock in 5th, 230kmh. stock standard vx ss. should see alot more of 6th gear now.
I have a 4.3 in mine, and the gearing is far too low (although Im using a w57 5spd) When I get a chance Im gonna stick a gts25 3.5 or a diesel laurel 3.9 centre in so I have some legs
looking close stuart....we'll post up track days in jan/feb in events section. I'm taking the production car out testing to a few would be good to see this frankenstein turn a corner too.
that would be great, but have a few things to finish, and not sure when ill get her back from the sparky.
but ill come along for a look anyway. was looking at getting it done for power-cruise, just so i could get it out somewhere to run it in and bed brakes in etc, but a track day would be better. its a shame superlap is on F1 weekend, would have loved to let her loose for that.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
