  • Replies 812
yeh lol. would have loved it, but sounds like a not so amatuerish event anymore, but cant miss F1.
Boz's track day is my goal.
yeah a net is all you need, and only on the drivers window.
hope its coming along ok....I think you might miss superlap...
Back from F1 and all syched to get this car going.
Up at the exhaust shop today, half was already done. I mounted the shielding
and the mounting brackets while Pottsy finished the last bend and started on the mounts.
Just the tips to go, some paint then all done. There was some cranky Chevs down at Melbourne.
Got the blood pumping.
Do the pipes join in that middle bend? i.e. exhaust gasses from each bank meet? or do they just meet and touch foreskins?
and Dick, get in line :sick:
it's an x-pipe. gas can flow between the two banks. :laugh:
interesting.
Its an ex-HRT trick that was only discovered by the other teams after Craig Lowndes put the car on its roof for all to see what they had designed.
see pic
Edited by DiRTgarage
Yeh its a pretty common thing these days. Its for balance Jas. and yeh they sound shit without them. The guy who designed the mufflers also gave me dimentions for the merged area in the X pipe and the reducer behind the collectors.
All these dimensions came from some software programme he had after entering some engine specs, ie bore, stroke, comp, estimated peak rpm, cam specs etc. the 2 1/2" reducer behind the collector eliminates the doughy dead spot you sometimes get down low by speading up the gas flow again as it cools resulting in scavenging the dead gas out of the cylinders leaving area for the new air fuel mixture to enter.
Sounds like i know what im talking about hey, but the scavenging thing was explained to me today in a way that i understood. It is also said that the area of the X pipe controlls the torque band. Its all a bit more complicated in a atmo engine thats for sure. But all these things combined are supposed to make for a good efficient system.
Pottsy put a tube in as to measure back pressure, appatently anything over 1.5psi at 5000rpm is getting excessive and can result in power loss.
He also decided that two 3" outlets on each side will look trick so just waiting for some collectors and it will be done.
Fuel rails are well under way also, have managed to find 15mm. Just hope its enough.
My clubbie runs an X-pipe system too
yeh i did see that, i hope its ready but thats only a month away, im waiting for my membership stuff to come back and then ill send off for the cams license. Ill give it a good shake but might be a late enterant.
looks good stu. SAU trackday is the place to debut it....plenty of laps to be had and no pressure
this build is so cool, love it... can't wait to hear that thing chugging away, and the looks on people faces when a 32 rolls past with a monster V8 burble... the exhaust and intake are giving me the 'orn!
you will post some video once its running... pretty please!
finally figured out the sway bar issue after some lenghty phone calls by the Auto 1 boys to Whiteline and red-Ranger and found a VL commodore turbo brace is the one to use. just have to make end plates and reverse the way it runs so across the front of the engine instead of around the back.
dont you love public holidays. Got a bit done, fabricated strut brace end-plates, painted them and mounted the brace. Also port matched the intake manifold and bolted it down for good.
Ill try to get a bit more done this week-end.
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
