  • Replies 812
yeh lol. would have loved it, but sounds like a not so amatuerish event anymore, but cant miss F1.
Boz's track day is my goal.
yeah a net is all you need, and only on the drivers window.
hope its coming along ok....I think you might miss superlap...
Back from F1 and all syched to get this car going.
Up at the exhaust shop today, half was already done. I mounted the shielding
and the mounting brackets while Pottsy finished the last bend and started on the mounts.
Just the tips to go, some paint then all done. There was some cranky Chevs down at Melbourne.
Got the blood pumping.
Do the pipes join in that middle bend? i.e. exhaust gasses from each bank meet? or do they just meet and touch foreskins?
and Dick, get in line :sick:
it's an x-pipe. gas can flow between the two banks. :laugh:
interesting.
Its an ex-HRT trick that was only discovered by the other teams after Craig Lowndes put the car on its roof for all to see what they had designed.
see pic
Edited by DiRTgarage
Yeh its a pretty common thing these days. Its for balance Jas. and yeh they sound shit without them. The guy who designed the mufflers also gave me dimentions for the merged area in the X pipe and the reducer behind the collectors.
All these dimensions came from some software programme he had after entering some engine specs, ie bore, stroke, comp, estimated peak rpm, cam specs etc. the 2 1/2" reducer behind the collector eliminates the doughy dead spot you sometimes get down low by speading up the gas flow again as it cools resulting in scavenging the dead gas out of the cylinders leaving area for the new air fuel mixture to enter.
Sounds like i know what im talking about hey, but the scavenging thing was explained to me today in a way that i understood. It is also said that the area of the X pipe controlls the torque band. Its all a bit more complicated in a atmo engine thats for sure. But all these things combined are supposed to make for a good efficient system.
Pottsy put a tube in as to measure back pressure, appatently anything over 1.5psi at 5000rpm is getting excessive and can result in power loss.
He also decided that two 3" outlets on each side will look trick so just waiting for some collectors and it will be done.
Fuel rails are well under way also, have managed to find 15mm. Just hope its enough.
My clubbie runs an X-pipe system too
yeh i did see that, i hope its ready but thats only a month away, im waiting for my membership stuff to come back and then ill send off for the cams license. Ill give it a good shake but might be a late enterant.
looks good stu. SAU trackday is the place to debut it....plenty of laps to be had and no pressure
this build is so cool, love it... can't wait to hear that thing chugging away, and the looks on people faces when a 32 rolls past with a monster V8 burble... the exhaust and intake are giving me the 'orn!
you will post some video once its running... pretty please!
finally figured out the sway bar issue after some lenghty phone calls by the Auto 1 boys to Whiteline and red-Ranger and found a VL commodore turbo brace is the one to use. just have to make end plates and reverse the way it runs so across the front of the engine instead of around the back.
dont you love public holidays. Got a bit done, fabricated strut brace end-plates, painted them and mounted the brace. Also port matched the intake manifold and bolted it down for good.
Ill try to get a bit more done this week-end.
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
