  • Replies 812
fancy engine swap Phunkey....they are cheap to build, engine owes me $5000 without the manifold. boys tuned a 6litre a month ago, camshaft, valvesprings and tune = 310kw.
Sounds awesome Stu, pity my clubbie doesn't sound like that!
Your car makes me re-think my deision to stay with my SR and not just put an LS in there, would have cost me a hell of a lot less that's for sure, and would probably end up being more reliable too. :rolleyes: Oh, and I'd probably be able to drive it by now!
Mine has LS1 edit, stock sized-custom exhaust and a K&N panel filter and makes 233rwkw's... very easy power indeed.
i am very happy so far. I will be extactic after the SAU trackday if everything holds together and the car performs well.
so far its just a noisy (mind you good noisy) V8 that makes good power. still might be better suited for drifting, god forbid ive yoused the D word.
That is simply mint.... you should be proud Stu >_<
pretty cheap too, $4k will buy you a complete LS2 6.0l brand new. Has alternator, water pump, balancer, steer pump compressor, and coils, throttle body everything.
Since this build has started ive started buying street machine mag again..and keep noticing those brand spanking LS2 Crate motors or Fords DOHC 5.0L lol
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
