Fair point all, I think though if all topics that are not "on topic" are placed in the wasteland we are just going to get everyone confused, and if you are reading something interesting it will get lost in all the other random posts, i haven't logged on here since last night (broadband down at work) and there is about 4 new pages just today! if i wanted to find something particular it certainly would get confusing.
I think having a subsection for something like "general SA members banter" would be a problem as we would have a subsection for a subsection, but things like "computer jargon" and "the pregnancy thread" "jokes thread" are a good read. Maybe people really need to have something that is interesting or important to SA people before starting a new thread maybe?
Discuss!!
Karl, I personally don't mind threads like Jokes & Computer Jargon, it's just some of the other crap that gets started that leaves me very cold and really wastes my time.
A good example of a recent thread (where I contemplated giving about 10 members a holiday) was that 9 page effort (all in one day) with 100 IBTL's and other crap in it.....I spent over 1 hour reading thru immature dribble, time I could've spent with my kids.
So how do we handle the crap threads and who calls the shots as to what's crap and what isn't........someone's rubbish can be someone elses gold, so I'd be dammed if I deleted and dammed if I didn't......how do you please everybody?? :P
Dave, if you want a hand doing the pads, I'll do them for you, gimme a call or message on 0431596795 :P
+1 for Helso doing your brakes Dave
did a great job on installing 4 new rotors and pads on my 33
pity they sssssssssssssssquell like f**k but thats not his fault
if any1 here can help me with a questions..may sound stupid but meh
im looking for GTR seats and wanting to know if any would fit into an R31?
yes, yes they can. pm matty t, hes a 31 nut, he'll be able to steer you in right direction... eventually.
the weber is at auto carby services getting the delux treatment. got a set of TRX meshies coming in on the weekend, and the fuel tank is almost keeping fuel inside it.
that will be all sorted soon as, all that will be needed next is getting some exhaust place to plum up between the turbo n the carby
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
